Go to Post I don't remember ever having "attack of the jumbo ball" in FRC! - Beth Sweet [more]
Unread 25-01-2009, 03:06
eatbuckshot eatbuckshot is offline
FRC #0611
eatbuckshot is an unknown quantity at this point
Trouble with Digital breakout IO PWM
Its really late, I'm having trouble using anything off of the digital breakout thing
tried to use DigitalOutput DigitalInput on all 14 pins tested setting values to true tested by probing to see if there was anything and attempting to short the signal and gnd... tried to set values for jaguar
i just have no idea what's wrong.
I do notice this in the console everytime i run any program
>>>>Fatal error "Digital module loop timing is not the expected value" in DigitalModu
le() in DigitalModule.cpp at line 56
DIO LoopTiming: 108, expecting: 261
i don't even know where i can find the .cpp i only see .h
Trouble Generaing PWM output RaiderRev Programming 3 22-01-2008 18:59
trouble with pwm speed controller jakk Control System 4 10-01-2005 02:51
trouble with pwm speed controller jakk Electrical 4 10-01-2005 02:51
Trouble with pwm outputs misterikkit Programming 16 17-01-2004 10:56
