Go to Post Support an awesome scholarship fund for deserving students by buying sweet CAH expansion packs? Heck yeah. - Cothron Theiss [more]
Unread 25-01-2009, 10:07
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
Team Role: Coach
May_Walter is an unknown quantity at this point
Orbit Balls
1. what is their wheigt is grams?
2. what is the name of the fabruc they were originally made of?
thanks a lot
May Walter, Team 3038.
Unread 25-01-2009, 10:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Orbit Balls
Weight is half a pound. That's 8 ounces. 8 x 28 g/oz = 224 grams (approximately).
The fabric is Spandex (like is used for bicycle riding pants)
Unread 25-01-2009, 10:27
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Team Role: Coach
Re: Orbit Balls
wow that was quick, thanks a million, you really helped us!
Unread 25-01-2009, 12:28
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Orbit Balls
And extras can be found at Walmart, I believe. We were able to get about ten additional the day after competition. Only problem is they are about ten dollars a ball
Unread 25-01-2009, 12:35
MrForbes's Avatar
AKA: Jim
Re: Orbit Balls
If you're in Israel, it might be a long flight to the nearest Walmart
Unread 25-01-2009, 12:40
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Team Role: Coach
Re: Orbit Balls
you got that right..
nothing is easy when located so far away.
Unread 25-01-2009, 15:42
OScubed's Avatar
OScubed OScubed is offline
Lee Drake, CEO, OS-Cubed Inc.
AKA: Lee Drake
FRC #1511 (Rolling Thunder)
Team Role: Parent
OScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond repute
Send a message via ICQ to OScubed Send a message via AIM to OScubed Send a message via MSN to OScubed
Re: Orbit Balls
May:
the bands on the inside can be made from lexan plastic, and the padding can be either very thin foam, or just cotton batting (we used cotton - cheaper and easier to work with). Although the original balls use a plastic connector to connect the bands when you fold them, we have used two holes (drilled in the end at a diagonal from each other) so that if you overlap the ring ends you can put a pop-rivet through the holes and attach. There are several good step-by-step construction instructions on Chief Delphi, or feel free to contact Team 1511 at www.penfieldrobotics.com for help with construction tips. Since we're making over 100 of them to host a local competition we've been getting pretty good at it
Cheers,
Lee Drake, CEO, OS-Cubed, Inc.
Business Mentor - team 1511
Rochester, NY
Building optimal, stable, secure solutions to your business challenges.
Unread 25-01-2009, 15:53
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Re: Orbit Balls
One of the coaches massed a few of them, and they are 235g.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 25-01-2009, 20:35
MrForbes's Avatar
AKA: Jim
Re: Orbit Balls
Originally Posted by NorviewsVeteran View Post
they are 235g.
Thanks for the correction!
Unread 25-01-2009, 20:40
AKA: Richard Raitt
FRC #1793 (Pilots)
Re: Orbit Balls
No problem, he wrote it on some of them. At first I thought we had bummed some orbit balls from team 2359.
______
Unread 25-01-2009, 21:33
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Re: Orbit Balls
Here are two links that might be helpful...
HOW TO: Make Homemade Orbit Balls
http://www.chiefdelphi.com/media/papers/2187?
and
Orbit ball template
http://www.chiefdelphi.com/forums/sh...ght=orbit+ball
You might be able to make them from these...
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Throwing Orbit Balls Skifanatic Rules/Strategy 26 07-02-2009 07:29
Orbit Balls spotted Alwaysgo General Forum 3 09-01-2009 14:55
Diameter of Orbit Balls? excel2474 General Forum 3 05-01-2009 12:33
