Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 25-01-2009, 11:26
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
Question camera tracking code
i need a camera tracking code not the same one in the frc updates... becuase we tryed it but it has alot of problems ..... plz someone help and put here there code for the camera tracking, also if it has a problems. we just wanna see other examples to chose the better
Unread 25-01-2009, 12:22
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: camera tracking code
I would guess that if you're having a lot of problems with the example code, that it is not the fault of the code itself. Many teams have used it and not had any issues once they understood how to set it up.
If you travel to the First Robotics Labview forum, you will find that several teams have posted their camera code. The Beachbots even have a fully functional vi (in the basic framework) that will drive your robot to the light if you configure it.
Other than that, I would suggest that you ask specific questions regarding what is not working so that we can suggest how you can correct your errors in configuring your system. Despite the gracious professionalism on this board, I doubt very many teams will be willing give simply give you camera code that they've worked hard on.
Unread 25-01-2009, 18:37
mahmosh's Avatar
FRC #1946
ok... we have the problem with camera tracking .. and when we search about the panfortarget in the WPILib we don't find any thing .. is it an updates problem?
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
Using kevin's code for driving and camera tracking razzoc Programming 3 18-02-2007 08:50
camera tracking geekofband007 Programming 15 15-02-2007 23:50
Camera Tracking Woes VideoMan053 Programming 4 29-01-2005 18:09
Camera Auto Tracking? Ryan Cumings Programming 9 22-01-2005 02:20
