| Thread Tools |
Rating:
Display Modes |
#31
Re: pic: DOC V: THE RING OF FIRE
So let me get this straight: Each of those tubes will spew ignited propane at the opponent, melting them to regolith so you can score on them?
What? That's not what "Ring of Fire" means? Oh. Actually, I like the design, and the CAD skills are excellent. I wonder if the wheelbase is too short, in that it might affect stability in a collision by causing the robot to tip over forwards or backwards. That can be managed in other ways, but it gets tricky. Also, using the bumpers as part of the frame's structure is a good idea, especially if you use high-grade material (not regular sheathing grade). Our chassis has a roughly similar shape, and we had some problems with flexing (try lifting a front corent); be prepared to address this as well. Very nice! |
#32
Are you making sure the cRIO case is electrically insulated from the chassis? It looks like you might be mounting it on metal.
That said, this is some beautiful CAD work and an interesting design. I hope it works well for you. |
#33
Are you planning on doing traction control with that wheel in the back?
#34
The back wheel is raised up off the floor about 0.2" keeping our robot from tipping backwards.
#36
Is that a compressor I see in the back right corner?
#37
yes it is... but we have since gone away with pneumatics.
#38
Yeah, I can see that. I'm also assuming that the device to help pull the balls out also pulls the balls up to the top of the robot. But that still means that you don't have that much range. So I'm guessing that your plan is to "corner" an opponet's trailer and dump as many balls as possible into the trailer. That means that whatever encourages the balls to leave ur bot must have the ability to get a lot of them out in a very short period of time. Which also means that whatever system that you are using to get the balls up to the top of the bot must be able to get them up at a very quick pace (cim with 4:1?).
But thats just guesses. |
#39
1 sucking the balls in 1 pulling the balls up 1 pushing the balls out |
| pic: FIRST RING | matt 1923 | Extra Discussion | 33 | 04-03-2008 21:35 |
| pic: Championship Ring | KF987 | Extra Discussion | 8 | 10-07-2007 17:41 |
| pic: Logo on Ring | Donut | Chit-Chat | 14 | 30-12-2006 20:33 |
| The Ring | Collin Fultz | Chit-Chat | 26 | 07-02-2003 16:18 |
| Presenting the FIRST forum ring | archiver | 2001 | 0 | 24-06-2002 00:42 |
