Go to Post Unless your HS students have earned BSEE and BSME degreees already, how can they lead or run an engineering team? - KenWittlief [more]
Unread 26-01-2009, 18:07
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
How does Synchronized initialize semaphores?
I am writing our robot code such that the camera processing is done in a separate task from the rest of the robot. However, I need to share some code between the two tasks. So I looked at the Synchronized class. It all appears to make sense, except that there is no call to a semaphore creation method. The VxWorks documentation makes it quite clear that one of these functions is vital to proper semaphore operation. So, do I need to make that call myself, or is it done elsewhere (not in Synchronized)?
Semaphores and Synchronized's byteit101 C/C++ 14 02-02-2009 17:26
Victors not synchronized - dual motor train roknjohn Control System 9 07-03-2005 18:51
Victors not synchronized - dual motor train roknjohn Electrical 8 22-02-2005 11:09
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
the application failed to initialize properly (0xc0000033) white_ChocOlat8 Inventor 5 25-08-2004 22:40
