Go to Post I would rather Andy Baker be at champs than Will.i.am. - Grim Tuesday [more]
Unread 26-01-2009, 21:26
Brandon_L Brandon_L is offline
doot doot
AKA: Brandon Liatys
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Every X seconds....
Ive been trying to figure this out and I cant. I want to decrease the value by one on a numeric object and cant figure it out. I tried loops, and inside the loops putting a elapsed time object, setting the time to 0.5 and unchecking auto reset, and having it reset when the time hits 1.0. That part works. Now I want to wire the time elapsed green wire to a relay enable. Then for input I wire the numeric object. For output I put a wire to the +1 numeric object, and from there back to the numeric object. It works perfectly without the relay, other then the fact it wont stop, but with it wont! I also tried hooking up LED and a switch to the signal/result ports and that works fine because the light would flash on and off. Its something with the numeric.
Any help would be pure AWSOMEness
1519 - Video of 10 Laps in 60 Seconds... Ken Streeter General Forum 24 22-02-2008 14:14
Robot Drive for 10 seconds penguain Programming 8 20-01-2008 20:09
Backup battery only lasts 10 seconds? dawilliams Control System 3 21-01-2007 13:33
pic: Four Seconds CD47-Bot Extra Discussion 9 30-03-2003 15:31
About the first 10 seconds stuy694 Rules/Strategy 2 04-01-2003 14:35
