Go to Post Teams need to make 'don't be a jerk' a part of their culture, and that culture needs to be explained to the parents who travel with you - Libby K [more]
Unread 27-01-2009, 00:10
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
Open motor reference on Slot 6 DIO Module
I thought I was a pretty decent LabView "coder" after using it for over 3 years, and I'm actually happy to say that I've found something that has stumped me. I am attempting to open a motor reference in the Advanced framework Begin.vi and select PWM channels for eventually controlling motors connected to the sidecar on the Slot 6 DIO module. Slot 4 is selected by default internally in the OPEN X MOTOR.vi and since there is not an external connector to the outside of this vi for selecting the slot, I can think of only two (relatively cumbersome) ways of changing the slot reference:
1. Change the lib vi to extend the slot through the vi connector. I have a feeling this would be a bad idea because updates would probably break this
2. Decompose the open motor output cluster and insert my new reference to the slot in the cluster output. Blah
I know there is an easier way and I appreciate the help
1 Open Slot for BattleCry WernerNYK Off-Season Events 1 09-06-2007 12:26
Gear tooth sensor / GTS on DIO 3,4,5,6? demerski Programming 5 07-02-2006 21:04
Taking apart the motor control module Adam Y. FIRST Tech Challenge 1 15-04-2005 14:02
Anyone have an open slot for IRI hotel room? miketwalker Off-Season Events 0 15-07-2003 21:45
Module 7 gear -- fischer price motor archiver 2001 6 23-06-2002 22:55
