Go to Post ...and leave your bumpers at home. - Andy Grady [more]
Unread 27-01-2009, 02:45
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Victor::Set not working
I am sure this is operator error somehow but I don't see it. I initialize a new Victor instance like this:
#define CARD_HELICALRAMP 4
#define PWM_HELICALRAMP 3
pMotor = new Victor(CARD_HELICALRAMP, PWM_HELICALRAMP);
and use it like this:
pMotor->Set(fMotor);
The pMotor member pMotor is *Victor type and fMotor is a float. The physical output is not updating. No error messages appear on the console. Am I doing something wrong? I know the function is getting called and I know the fMotor value is in the correct range (I put a printf just before the line above).
The Set call is from a different task but that should not matter (I think). This is the only PWM I have declared at this point (no RobotDrive or anything else). Does that matter? I have only one sidecar hooked up to the DIO in slot 4. This is wired to PWM 3. Do I have to start at PWM 0 for some undocumented reason?
Any advice or help is much appreciated!
Can not set team number on DS TekClaz FRC Control System 2 23-12-2008 14:25
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Issues with non working victor constant orange led dani190 Control System 10 21-12-2007 22:32
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
