Connection with cRIO
I want to build a nice console and to get the joystick's values,Gyro's value
and so on .How i connect myself to the cRIO NOT from windriver? I mean from another software , can i get those values from ip and port? |
Re: Connection with cRIO
You can either connect via the serial port on the cRio, or use the dashboard data and the labview dashboard app to display the data.
There are instructions how to configure the serial port for console output in one of the control system documents, but I don't remember which one. There is an example of how the send the dashboard data in the Wind River samples, but you would need to modify the labview dashboard to work with your data. |
im not working with LabView so i want to make an alternative to it by myself.
Can anyone direct me to some guides or documents?i searched in usfirst... ![]() Last edited by nadavsen2 : 28-01-2009 at 17:54. |
![]() If you want me to send you the current draft of my documentation send me a PM or e-mail (public [at] ehaskins [dot] net), and I'll send you a copy. |
i sent you an Email , if you didnt get it , send it to "nadavsen2@gmail.com"
thanks alot ![]() |
| cRIO configuration issue- serial connection to laptop | Torbots 1197 | FRC Control System | 5 | 28-01-2009 22:28 |
| Bluetooth with cRIO/DS? | hellochar | Programming | 3 | 22-01-2009 17:20 |
| cRio losing connection when "run as startup" | mgurgol | Programming | 2 | 12-01-2009 12:18 |
| problem with connection | seanl | Programming | 1 | 29-01-2007 10:41 |
| Teams with an ASME Connection Wanted for Publicity | Vince | General Forum | 0 | 18-06-2002 12:24 |
