Trailer hitch spacer info???
Hey we are trying to connect our trailer to the hitch on our robot and I was hoping somone could tell me where to find the trailer hitch swivel that connects the trailer tongue to the hitch?
I dont know if we make it ourselves from electrical conduit or what. |
Re: Trailer hitch spacer info???
You have read <R18>, correct? Part C tells you that the one and only swivel point is a pin, McMaster part # 98416A009.
![]() Part Number: 98416A009 $1.86 Each Material Type Steel Finish Zinc-Plated Pin Type Safety Pins Safety Pin Type Squared Retainer Snap System of Measurement Inch Diameter 1/4" Overall Length 2-13/16" Usable Length 2-1/4" Inside Clearance 1-5/8" Specifications Met Not Rated From http://www.mcmaster.com |
yeah I read <R18> but Im talkin about the trailer swivel in the drawing not the trailer pin.
"GE-09040" It shows a swivel that is attached to the trailer tongue and then the other end of the swivel is connected to the hitch by the pin. Do you know where i could find this trailer swivel? Last edited by jph399 : 28-01-2009 at 17:35. |
Do know of a place we can get it so that we can practice with it before we ship it?
If you built your trailer according to the team specs the payload trailer tongue is longer than the tongue on the competition trailer to compensate for the swivel. |
Aight thanks, appreciate it.
Please note that the drawing 09040 Rev A is now misleading. The changes in 9036 Rev B are not reflected.
Also note that the hitch arrangement of the team trailer as specified in the team drawings no longer has characteristics similar to the official part. If you don't mind towing a boat trailer with a 2 /5/16 hitch with a 2 inch ball on your vehicle, then this "fine point" probably won't matter to you. If you've ever mismatched the hitch and ball sizes you'll have some idea of the effect of this change. Make sure you load ALL of the latest drawings or you may have some surprises awaiting at competition. |
#10
If possible could you elaborate on the characteristics which differ from the team trailer mock-ups and suggest a way that teams could modify their team spec. trailers to behave more like the competition trailers (if this can be done)? |
#11
The easiest way to get close is to use the 0.625 aluminum shaft in the kit (assuming you haven't used it for other things) and bore a 0.375 hole matching 9036B. You can also round the edges of the rod. You then need to shorten the galvanized section, and drill a couple of holes vertically and horizontally to lock the aluminum pin to the tongue. This will get you close. The aluminum is not as durable as the 1018 steel but should behave pretty much the same until you wear it out. |
#12
Thanks for bringing this to our attention. It was pretty well hidden...
| Trailer Hitch | punjabiblood | Technical Discussion | 12 | 26-01-2009 20:19 |
| Trailer Hitch | ewyllie59 | Technical Discussion | 8 | 24-01-2009 15:00 |
| Trailer Hitch Question | hawk_11 | Rules/Strategy | 4 | 06-01-2009 20:21 |
| Trailer Hitch | ewyllie59 | General Forum | 7 | 06-01-2009 08:33 |
