Go to Post Students leave and new students come. But mentors are forever. - fredliu168 [more]
Unread 28-01-2009, 18:39
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
carmen ball handling
http://www.youtube.com/watch?v=JWhlxw5pfIM
here is team 842 Falcon Robotics ball handling once the harvester has it.Also showing how it will get from the hopper into the vertical chute for launching
Faridodin "Fredi" Lajvardi KD7WKD
Unread 28-01-2009, 22:01
teampronto's Avatar
teampronto teampronto is offline
ʇsı1ɐıɔ&#4
AKA: Ka'i Kau
FRC #3070 (Team Pronto)
Team Role: Coach
teampronto is an unknown quantity at this point
Send a message via AIM to teampronto Send a message via MSN to teampronto
Re: carmen ball handling
Very nice Ledge! Say, could I ask you a question? We are having trouble picking a good way to make a quarter pipe curve. We are thinking aluminum with bracing to make it that shape. Should we maybe look into plastic? If so what kind? Thanks.
We are rookies
Unread 28-01-2009, 22:05
mfoyil's Avatar
mfoyil mfoyil is offline
AKA: matt foyil
no team (Blue Screen of Doom, idk any more)
mfoyil is an unknown quantity at this point
Pretty cool, ours is going to look kind of like that when it's finally done
Unread 28-01-2009, 22:30
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Should this be in robot showcase?
Sorry, that sounded bad, very good mechanism, and good idea sharing your progress.
Unread 28-01-2009, 22:33
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
EXCELLENT! We have a very similar design that collects from a hopper and the floor. Our original idea for what you call "the harvester" and what we call "the chicken pluckers" consists of pneumatic tubing. Is that what is being used here?
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 29-01-2009, 11:44
AKA: Ledge
Team Role: Teacher
We are rookies
You might try lexan. Find a can or pipe that is the shape you want and then heat the lexan with a heat gun to melt it into place around the pipe. You might also look at PVC or abs Pipe that is the diam you want and just cut it. Good luck
Unread 29-01-2009, 11:45
AKA: Ledge
Team Role: Teacher
You betcha!
Unread 29-01-2009, 13:50
jgraber jgraber is offline
jgraber is just really nicejgraber is just really nicejgraber is just really nicejgraber is just really nice
How to make a quarter pipe curve
[quote=falconmaster;810332]You might try lexan. Find a can or pipe that is the shape you want and then heat the lexan with a heat gun to melt it into place around the pipe. You might also look at PVC or abs Pipe that is the diam you want and just cut it. Good luck
For our shooter quarter pipe, we are planning to cut radiused side walls in plywood, and bend 14" wide steel flashing around it. The flashing will have 1.5" tabs notched into the sides and bent at 90" angles to be screwed to the outside of the plywood. The flashing will have each 2" segment bent 5-10degrees with a cheap sheet metal hand brake to provide some stiffness across the gap. Haven't done it yet, but thats the plan. Probably need "lightning" holes in the sides, also for visibility of balls getting stuck. Also traction mat glued to the flashing and the shooting wheel.
Unread 29-01-2009, 13:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
How you make the quarter pipe curve might depend on what else the balls are doing that will ride on it. We are using some thin 3/4" poly tubing as bottom and side rails, to guide the balls up from the harvester to the shooter, with a kind of flapper wheel thing in the middle to drive them. If the balls will be compressed against the quarter pipe, then it needs to be pretty substantial, and the idea of using several plywood supports sounds good.
Oh yeah...nice job Falcons! Looks like you're getting the pieces of the puzzle all put together
Unread 29-01-2009, 15:57
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Make sure those spikes don't leave the bumper perimeter.
Unread 29-01-2009, 16:26
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
wow very nice, how did you connect the polycord? Is that urethane belting that you are using? hmm, we were thinking about doing a lift similiar but oriented a little differently using 1/8" urethane orange belting...do you think 1/8" urethane belting is good enough to grip the ball? Thank you for sharing your knowledge with the FIRST community
Unread 29-01-2009, 16:40
AKA: Ledge
Team Role: Teacher
We are not that familiar with the other materials you mentioned, we are using green polycord from Duracord. It rips the balls good. It doesn't stretch much, but enough .
Unread 29-01-2009, 16:41
AKA: Ledge
Team Role: Teacher
We will make sure thee tubes are in dimension
Unread 29-01-2009, 16:43
AKA: Ledge
Team Role: Teacher
Thanks Jim! How are you guys?
  #15   Spotlight this post!
Unread 30-01-2009, 10:50
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Looks like a solid design coming together 842. Now we just have to wait and see how orbit balls will be flying out of top of this year's robot...
Have you tried driving up to balls and picking them up yet?
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Carmen Electric's Ball Transport falconmaster Technical Discussion 4 23-01-2009 14:47
Didn't Like Digital Handling Anime-niac_2.9 Programming 1 05-02-2007 13:46
Hanging yourself or Handling Big Ball? punarhero General Forum 15 27-05-2004 17:57
handling loose wires/hose/cable Max Lobovsky Technical Discussion 5 24-02-2004 16:53
A New Method of Handling Nationals archiver 2001 9 24-06-2002 03:30
