Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
Unread 28-01-2009, 19:34
gorrilla's Avatar
gorrilla gorrilla is offline
AKA: adam spears
FRC #1557 (12voltbolt)
Team Role: Driver
Rookie Year: 2007
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
pic: 1557 3rd week progress
Unread 28-01-2009, 19:37
gorrilla's Avatar
AKA: adam spears
Team Role: Driver
Rookie Year: 2007
Re: pic: 1557 3rd week progress
so this is what we've been working on for the past 3 weeks or so...
the square aluminium in the middle of the "thresher' goes inside of a 4in.pvc pipe with pnuematic tubing on the outside to push the ball up the "screw"
Adam Spears
2010: Florida Regional Finalists.
2010: Goveners Award.
2010: Florida Regional Judges Award.
2010: UL Saftey award.
2009: Florida Regional Chairmans
2009: Rockwell Automation Innovation in Controll Award.
Unread 28-01-2009, 19:39
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Very nice looking Archemedies screw.
Whats it's capacity? Will the center turn when fully loaded? Whats the load rate into the shooter?
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 28-01-2009, 19:47
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
That looks awesome! Good luck!
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 28-01-2009, 19:48
gorrilla's Avatar
AKA: adam spears
Team Role: Driver
Rookie Year: 2007
1.it should hold 20-25 balls(depending on how much they "smush" inside the thresher)
2. it does,(powered by a keyang)the pnuematic tubing lays flat against the pvc tube after a certain pressure point(that way we can just leave it running the entire match)
3. one at a time right now, we dont have a lot of space to work with...
ps.the shooter rotates left and right(via a denso)
...its weighs suprinsingly little(maybe 50 pounds at the most)
...its going to have an awsome paint scheme too...
Adam Spears
Unread 28-01-2009, 20:38
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Anticipate lots and lots of full speed multi-bot collisions, including getting pile-driven from two sides at once. The frame in the picture, or somethig wrapped around it, is going to need to be sturdy enough to survive the punishment.
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 28-01-2009, 20:48
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
Rookie Year: 2007
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
You might wanna make sure thats 60 inches tall
Unread 28-01-2009, 20:52
FIXIT's Avatar
FIXIT FIXIT is offline
FRC #0120 (Red Dragons)
FIXIT is a jewel in the roughFIXIT is a jewel in the roughFIXIT is a jewel in the roughFIXIT is a jewel in the rough
Is your robot a six or four wheel system -- not sure if you have a wheel at the front edge?
Cleveland's Team - The Red Dragons
Youth Technology Academy ---Cuyahoga Community College
Unread 28-01-2009, 21:07
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
I'm fairly sure it is. It's just on a cart in the picture.
Looks like you still have some work to do. Stop posting pictures, get the robot readier, and post some more pictures!
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 28-01-2009, 21:08
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
In that order.
Unread 28-01-2009, 21:16
Pat Arnold's Avatar
Pat Arnold Pat Arnold is offline
I think I over-think things...
FRC #1557 (12 Volt Bolt)
Pat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond reputePat Arnold has a reputation beyond repute
The majority of impact during play should occur at the bumper level...this is a welded tubular frame, hopefully it will be okay.
"Gorrilla" might have used optimistic math; I'd guess the "spinning tube of death" will hold closer to 18-20 orbit balls at one time.
2005 -2008 MARS Team 1523 Mentor/NEMO Member
ME's wife & Tim's mom
Geocaching is my other obsession..."Using multi-million dollar satellites to find Tupperware in the woods".
Unread 28-01-2009, 21:36
gorrilla's Avatar
AKA: adam spears
Team Role: Driver
Rookie Year: 2007
i renamed it the "thresher"
4wd, we figured wheels at the front edge would'nt be needed?
its 5.5 balls around, and theres 4 levels on the spiral and they squish quite easily
ps.its 59 inches tall....
you should see how stiff it is since Craig welded, it nearly impossible to flex it
IF we can find pool noodles....
Adam Spears
Unread 29-01-2009, 23:14
Ian H. Ian H. is offline
FRC #5026 (Iron Panthers)
Ian H. has a little shameless behaviour in the past
I really like the idea of cutting down on polycarb by only having the strip running up where the ball will touch it, also looks cool like that. cool, simple and seemingly obvious, but I hadn't thought of it before.
1557 rolling chassis gorrilla Robot Showcase 4 19-01-2009 22:38
pic: 3rd iteration swerve Aren_Hill Extra Discussion 5 21-03-2008 19:09
pic: Team 1345, end of 3rd week. Arefin Bari Extra Discussion 14 29-01-2007 08:44
pic: 3rd mecanum prototype TheOtherGuy Extra Discussion 4 16-11-2006 00:55
