Go to Post Think outside the bot. Find a different regional someplace you never considered before. There's plenty of them. - Koko Ed [more]
Unread 28-01-2009, 21:06
Xavier Brandall's Avatar
Xavier Brandall Xavier Brandall is offline
FRC #1245
Xavier Brandall is an unknown quantity at this point
Error 44085
When we try to deploy some of our code we get the error:
"Error -44085 Occured at FPGA Bit file has incorrect version or revision."
We have looked around at the other threads already posted asking about this error, but have found no useful information. We have fully updated software on our computers. When we run the camera servo example, it works, but when our slight modification of this code is run, we get the error. It has yet to occur on any other code. Any infromation on how to solve this problem would be fantastic.
Unread 28-01-2009, 21:52
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
Re: Error 44085
Did you re-flash with a full power on reset?
Unread 29-01-2009, 09:25
Re: Error 44085
I agree. I don't have the error code in front of me, but I think it indicates an incompatible FPGA image. Rerun the imaging tool, and make sure to click on the format checkbox. Expect it to take fifteen minutes or so.
Greg McKaskle
Unread 29-01-2009, 09:42
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Re: Error 44085
That actually happened to us when some of the newer members opened the "RobotMain.VI" instead of the project file and tried to run that. Are you sure you've opened the .lvproj file?
Error code -44085 Robo-Panthers NI LabVIEW 3 25-01-2009 11:36
Labview error code -44085 help zackcool123 NI LabVIEW 2 19-01-2009 09:18
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
