Signal wire gauge and color.
I'm pretty sure we can use 24 gauge wire for for hooking up a potentiometer. Do color requirements not apply to 5v sensor wire, or do I need to get some red black and white 24 AWG wire?
Re: Signal wire gauge and color.
R46:
• Connect the wiper to the input pin – Top row.
• Connect the other two pins to +5 and ground – Middle and bottom rows. There is a thread about this. http://www.chiefdelphi.com/forums/sh...oten tiometer If that helps that is. |
Sparrow,
Although there is no strict rule governing sensor color code, standard practice would make that recommendation. R46 above relates to power distribution as Abwehr pointed out and those colors may be used. A PWM cable makes a perfect connection medium for your application and will maintain a color code that both you and others can easily identify. Red for positive voltage, black for common and white for signal or in your case, pot wiper. |
Gauging can be light for sensors and signal devices. We've always followed the practice of using red for V+, black for GND, and white as a signal color.
PWMs are perfect for this as they give you the connector on the other end if you are connecting the device directly to an input. |
| Spike Relay Wire Gauge | sparrowkc | Electrical | 7 | 12-02-2008 14:26 |
| Wire gauge vs. current | AdamHeard | Electrical | 7 | 09-11-2007 10:36 |
| Wire Gauge Question | Neghman | Electrical | 1 | 14-02-2004 19:56 |
| Line sensor wire gauge questions | Dinush | Electrical | 6 | 13-02-2004 18:41 |
| 11 Gauge Wire...where? | Matt Krass | Electrical | 6 | 21-01-2003 10:17 |
