belts
okay so the situation is we have the 4ft cog belt that came with the kit we need it shortened and to be able to attach the 2 ends any ideas?
Re: belts
If you'll give me an hour or so I have a student that can answer this question for you. If it's the belt I'm thinking of you can cut it and then meld it back together. As soon as I see Robogeek99 I'll show him your post and get back with you.
Re: belts
The Gates information that came in the Kit says the belts can't be field connected or spliced together other than by using clamp plates.
http://www.team358.org/files/mechani...esForFIRST.pdf |
Re: belts
dont think melting them together would be that safe anyways...
so IMO i wouldnt try that... |
Re: belts
We just order more belt from B&B manufacturing today. If you have the room in your robot, and you don't want to modify your belt; you can just wrap belt along in circles. Also if you must modify your belt, be careful of the rules; melding the belt isn't not allowed. You must check completely with the rules.
Re: belts
I don't see one. It's not a motor or a control system component, so it can be modified; it's not electrical, so there aren't limits on that. |
Re: belts
Re: belts
In the past, wasn't there a rule against chemically altering kit parts? It doesn't seem to exist this year.
Re: belts
It's been years since that one was around. Maybe back around the time when I was a rookie was when it disappeared. (Note: my official rookie year was 2003. I hung around long before then.)
| BELTS?!?!?!?!? | Mac Generals | General Forum | 3 | 27-01-2009 16:03 |
| Timing belts | kajeevan | General Forum | 6 | 13-08-2008 13:59 |
| Belts vs. Chains | Mikhail_Pham | Technical Discussion | 33 | 02-03-2008 23:21 |
| Long Belts | FourPenguins | Technical Discussion | 9 | 21-08-2007 19:10 |
| Belts, Timing Belts, and Automobiles. | Anton Abaya | Technical Discussion | 5 | 09-01-2002 19:21 |
