Go to Post I continue in FIRST because I'm not looked down upon for not knowing how to do something, but held up because I want to learn. - LemmingBot [more]
Unread 29-01-2009, 16:57
lingomaniac88 lingomaniac88 is offline
FRC #1554
Rookie Year: 2007
lingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud of
Connecting to the cRIO
Right now, we are downloading code to our robot through the connections as described in the Control Systems Manual. We are able to transmit the code from the computer wired to the DS, which is wired to the router, and connecting the wireless bridge to port 1 of the cRIO.
Is it possible to communicate from the laptop to the router wirelessly, or do we have to have a hard connection as described above?
This is not for the competition; this is only for our own purposes.
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all, try something."
-- Franklin Delano Roosevelt.
Unread 30-01-2009, 10:58
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Connecting to the cRIO
As long as your laptop is capable of connecting to the 802.11n router, you should be fine. Having the 10.x.y.6 IP address is still necessary if you want to receive Dashboard data.
Trouble connecting to cRIO? darty Programming 17 31-01-2009 16:15
Connecting to cRio, getting the jaguars to go solid yellow.... then nothing. DSST\neal.ian FRC Control System 11 30-01-2009 18:15
Connecting Axis camera to cRIO laultima FRC Control System 20 21-01-2009 16:56
Help! Connecting CRIO to the Power Block RyanJK Electrical 3 07-01-2009 17:28
Connecting Power Distribution block to cRio Paul Rodi Electrical 2 05-01-2009 18:20
