Detecting the top of the trailers
All the trailers in the competitions will have pink and green stripes on the top of the trailers. Will the camera's code allow for a slight change in shade for detecting these, or will we need to get the exact shade? If we must the get the exact shade, where can we get the stickers that have these shades of green and pink?
Thank you for your help and time, Comatose |
Re: Detecting the top of the trailers
Additionally, you can and should allow for a variation in shade due to lighting. If you go to the documentation for the control system on usfirst.org, you can find fully-functional sample code for camera tracking.
Ah, well that would work :| . I feel silly. Now that that's out of the way, compared to the video that explained the game, these sheets seem larger than those depicted in the video. Do we know the dimensions of the green and pink sheets on the trailer?
Thanks, Comatose |
From drawing GE-09028 in the game specific drawings zip file on FIRST's website, each color appears to be 12 inches high and wrap all the way around the vision target.
The sheets in the Kit are actually slightly smaller than is required, but are enough to make one side of the trailer appear on the camera. (The kit sheets are 12x12, the actual target is a 12" height 8" diameter cylinder, so would require a 12"x~25" sheet.) I'm sure FIRST lists a supplier somewhere in the manual.
| Time to the top... | Joe Johnson | Robot Showcase | 60 | 14-04-2003 20:23 |
| How do you tell whether your sensor is detecting a crate or the diamond plate? | Greg Ross | Technical Discussion | 4 | 13-01-2003 19:02 |
| Q&A Discuss: How long is the bump from the ramp to the top? | CD47-Bot | Extra Discussion | 1 | 11-01-2003 09:48 |
| How long is the bump from the ramp to the top? | Tton | Rules/Strategy | 1 | 09-01-2003 18:26 |
| Surface of the top of the ramp polished? | Eric Reed | Rules/Strategy | 5 | 05-01-2003 23:25 |
