Go to Post Good Luck all - this one will hurt your brain, but it's all in a good way. - meaubry [more]
Unread 29-01-2009, 19:48
starsROBOTICS starsROBOTICS is offline
FRC #2276 (S.T.A.R.S)
starsROBOTICS is on a distinguished road
2 Joysticks, 2 Triggers, 1 relay, 1 problem
Ok so i have looked at the threads and i found everyone of them to be similar to what i am asking and if it was what i was asking they didn't help much. So i am going to explain thoroughly. I want to have the 2 Triggers on the 2 joysticks controlling 1 relay to go forward when Button 1 of joystick 1 is pressed and reverse when Button 1 of joystick 2 is pressed and Neutral when none are pressed.
What i have done was unbundle both joystick buttons. Wired both button 1 of both Joysticks to their Seperate "select" function(T/F). Created a forward constand and wired it to the True statement of the select function and off for the false statement for the joystick 1. I did the same for joystick 2 but instead of forward i did reverse. i wired the right ends of both of the "Select" functions to a "or" Statement and wired them to the Relay set box.
I thought this would work but the relay doesn't reverse. it only goes in 1 direction.
Can anyone tell me why?
<added info>
I also looked at the digital sidecar and the relay light turns red when i push 1 trigger and the relay turns green when the other is pushed but the relay does not turn green just red
spike relay problem? Maxpower57 Electrical 15 09-04-2012 19:18
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Joystick Triggers No Longer Work amateurrobotguy Technical Discussion 7 04-04-2006 13:58
Help! Programming question with triggers AsimC Programming 26 18-03-2004 11:00
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
