Wheel Placement
Our team was having a debate on wheel placement today. Will wheels that are farther apart (right to left) give the robot more control/traction/turning ease? Or should the wheels be closer together? I think that on the low traction floor more distance between the wheels would be better.
Not that it is really going to change our design, but I was wondering if all the other experts out there could give me a confirmation on this. Thanks. |
Re: Wheel Placement
A longer wheel base is more stable front to rear but will sometimes have turning issues. A longer track (Width) Will usually result in better turning and better lateral stability but will tend to tip a bit from front to back.
If you're going for good turning it's usually best to have the wheels as far apart as possible. (Width-Wise) |
Re: Wheel Placement
I agree, our robot was designed with a short wheelbase and it turns much better than if it were the length of the bot.
| Lowered Center Wheel for 6 wheel drive | 987HighRoller | Technical Discussion | 37 | 17-01-2007 01:21 |
| Spoiler Placement | mdicicco | Rules/Strategy | 14 | 11-01-2007 12:51 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| Placement of Robot | Shawn60 | Rules/Strategy | 3 | 18-01-2003 23:51 |
