Go to Post It's often not the code you are focused on that causes problems, but the code you dismiss out of hand as "unrelated". - Mark McLeod [more]
Unread 29-01-2009, 22:54
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Ball Capacity? How Much is Too Much? And Can You Use It For A Strategical Advantage?
In my infinite hours of thought I've come across a question. How Many balls can your team possess and how many is too many?
My team should able to possess about 20 balls at a time. But I thought to myself are we ever going to be able to use all of those balls? Can We score them Fast Enough? Which Then Led me to think of how ball possession and how many you possess can play into your strategy.
In Lunacy there are a limited number of balls. Each team is given 20 to start with (Up to 7 in a robot) and after they're scored they cannot be reused (unlike 2006) which would mean that if you could hoard all of your opposing alliance's balls and hold onto your own you could effectively limit their scoring capacity.
Or there's always the strategy of passing balls between alliance members. Seen in this video at about 3:50:
http://www.thebluealliance.net/tbatv...hp?matchid=620
Discuss.
(The intent of this thread is to discuss theoretically strategies only. Not any in depth robot capabilities beyond theoretical ball capacity.)
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
How do you notice that you spent too much time in Autodesk Inventor? Chris Herold CAD 14 20-02-2009 00:02
How much do you pay for airfare? BobC Championship Event 20 17-12-2006 14:54
How much of our wheel used for the shooter can be exposed? waialua359 Technical Discussion 4 14-02-2006 13:27
How much did YOU Pay for the tubs? yangotang Kit & Additional Hardware 6 14-01-2003 19:44
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
