Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
Unread 31-01-2009, 00:56
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
camera setup procedure
Does anyone know of a published procedure to stting up the camera to run with the vision demo code? Is it just the simple matter of connecting the servos to PWMs 9&10 and the crossover connector to cRIO, changing the password on the camera and then deploying the code to the bot? I think i have everything connected good just wanted to check with others first before pulling out my hairs.
Unread 31-01-2009, 01:00
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Re: camera setup procedure
If you have the control system document, there's a small part in chapter 5 I believe about setting up the password on the camera. Make sure you've done that, then just hook up the camera to port 2 on the cRIO, ensure it and everything else has power, plug the servos in the appropriate ports and it should come to life!
...should... you know how programming goes...
Unread 31-01-2009, 22:36
FRC #2477
We got it working. Thanks!
Can't figure out the Axis camera setup... 2829ron Technical Discussion 6 20-01-2009 13:12
Setup Axis Camera - ERROR Bruno Inácio Technical Discussion 2 16-01-2009 12:37
Camera to motor setup Windward Programming 24 18-02-2006 20:29
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Is the suggested Vision Camera setup ILLEGAL?! Mr. Lim Rules/Strategy 37 20-01-2005 21:46
