Go to Post I believe that "going home a winner" is more a matter of perception than anything else. - JesseK [more]
Unread 31-01-2009, 12:38
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Rookie Year: 2007
Team1710 is an unknown quantity at this point
1710 Code
I'm attempting to program a shooting turret based off the TwoColorTrackerDemo provided.
I've modified the code so that instead of moving servos on an x and y basis and calculating where they are, all I want to do is use the par.center_mass_x_normalized value (a value between -1 and 1) to set my turrent motor to turn left or right until its centered. So basicly, I'm writing code for a tankl like turret to spin until its centered on the x axis with the target.
The code is attached. The camera isn't even picking up the image when downloaded to the robot. I'm a novice programmer, but I'm the only one my team has and I figure letting some experts see this will save me a lot of time then my struggling through it for a few extra days that we don't have.
Thanks!!
Team 1710 Needs a part FRC1710 Technical Discussion 2 21-01-2008 17:00
pic: Team 1710 has a wroking Robot! FRC1710 Robot Showcase 6 15-02-2007 12:42
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
