"No code" each time cRIO is rebooted
Hi all,
We're having a problem loading code onto the bot with the new WPILib update. The first time the cRIO is started, and you run your user program directly, it still says "No Code". Only when you delete the program from memory and run it again does it start working. This did not happen until we updated WPILib and the cRIO/FPGA firmware. Any one else having this issue? Any ideas? |
| cRio losing connection when "run as startup" | mgurgol | Programming | 2 | 12-01-2009 12:18 |
| Team 1261 - cRIO on 2008 "Longshot" | Tanner | Robot Showcase | 2 | 31-12-2008 12:44 |
| "Battery: No Code" after uploading .out file to cRIO | knine143 | FRC Control System | 1 | 20-12-2008 22:14 |
| Getting two Vex controllers to "talk" to each other | thefro526 | Programming | 1 | 28-05-2007 11:59 |
| Coolist "bot" in each division | Michael King | Championship Event | 46 | 21-04-2003 18:20 |
