Go to Post I'm impressed and incredibly amused that you found so many of Dave's evildoings, though granted, they aren't that hard to search out. - DCA Fan [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 31-01-2009, 13:57
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
video post Q's
We are compositing our movie in Video Post.. We can take 2 sequences and do a cross fade. No problem. However, if we want to cros-fade 3 sequences - A cross-dissolves to B, and B cross-dissolves to C. Can't do it! It seems that only 2 items can be cross dissolved. I have to say this is STUPID! Even your basic consumer video program comes with these basic tools.
What we have to do is corss-fade A and B, then render those to a movie.. start a noew Video Post project, and bring in our rendered A-B as one movie. Then we can cross-dissolve that to part C. Anyone know how to do this?
Overlaps indicate our cross-dissolve.
PHP Code:
-----A
-------B
Unread 31-01-2009, 16:43
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: video post Q's
make another B so you can crossfade the B and C. It should be a seamless transition between Bs
PHP Code:
-------a
-----b
-----b
Problem solved.
*Flies off* WOOSH!! "SPOON!!"
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 31-01-2009, 16:50
AustinDpOwers89's Avatar
AustinDpOwers89 AustinDpOwers89 is offline
Rookie Year: 2007
AustinDpOwers89 is infamous around these partsAustinDpOwers89 is infamous around these parts
Re: video post Q's
PHP Code:
-------a
-----b
-----b
Problem solved.
*Flies off* WOOSH!!
lol, yeah... exactly... split the B in half and u should be good, unless of course your B clip is so small that it won't let you crossfade into the 1/2 length of it. idk if that program allows you to shorten the video length of your cross fade but yeah you could do that as well. if the intial problem was that your B clip is too short and it won't let you start a second cross fade because your first one isn't done yet, then yeah either you shorten the length of the crossfades or you lengthen your clip.
Unread 01-02-2009, 21:26
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Re: video post Q's
Make three planes in an orthogonal view so that they perfectly fit the render dimensions. Put your videos on them as textures, then animate their transparency.
Unread 03-02-2009, 14:02
FRC #0847
Re: video post Q's
How about this: Render each frame - print dye sublimation prints, scan each print at 300 dpi, downsample to video res. Then map those images to an orthoginal rectangle and render with motion blur, depth of field and GI turned on.
Thanks for the suggestions, but it still seems like a crazy work-around.
Unread 03-02-2009, 23:22
FRC #1720
Re: video post Q's
You can do all kinds of cool stuff! Every cheesy 3D transition you could ever want is at your fingertips. Add the explode modifier to a video clip! Use the melt modifier as a transition! Turn a clip into cloth and run stuff into it! The possibilities are endless!
(Don't actually do any of that please. Unless it's your credits. I'll make exception for credits. )
Unread 03-02-2009, 23:37
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
Re: video post Q's
I'll ad even more!! you can write a script so particles appear where values of red blue and green appear and construct your video that way!! Whoa!! it just hit the fan! I'm seeing around corners!
A.K.A Llama
Vex bot programming Q's BaldwinNYRookie Programming 6 09-10-2005 17:45
General Q's amateurrobotguy Programming 8 23-02-2005 16:59
General Q's amateurrobotguy Control System 1 22-02-2005 20:05
Judges Q's Hershey General Forum 2 07-02-2005 11:19
CD Q's? Jack Website Design/Showcase 1 18-10-2002 11:08
