Go to Post Let it be noted in the annals of FIRST history that on this day the game design committee did NOT choose to change, clarify, explain, or interpret ANY PART of the 2010 Manual. - Richard Wallace [more]
Unread 31-01-2009, 15:09
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Problems running Default LabView Code Version 3.0
We are trying to program our robot in Labview and are not having much success:
In earlier versions we were getting motors/sensors to run fine, but when we upgraded to version 3.0, we cannot get any pwm output, even with the default code. LabView seems to deploy fine and we get no errors in the cRio and the Driver Station, but there is no apparent signal from PWMs 1 and 2 (with joystick connected to USB 1).
We applied the firmware upgrade and everything, still with no luck.
Anyone else have similar problems?
Unread 31-01-2009, 16:51
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
Rookie Year: 2007
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
Re: Problems running Default LabView Code Version 3.0
Did you re-image your CRio after you updated labview?
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
Unread 31-01-2009, 22:51
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Even though you've updated the cRIO with the latest v11, I'd suggest reformatting it one more time.
Unread 31-01-2009, 23:10
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
I upgraded my vista laptop to version 3 and now the Gyro - Get Angle vi is broken (see screenshot). Is this a problem everyone has, or should I re-install?
When going from version 2 to 3 should we be able to use the same projects without modifying anything or re-inserting the WPI sub-vis?
Thanks!
Unread 31-01-2009, 23:23
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
There is a problem in 3.0 and 3.0a with the Gyros.
See this thread on the First forum:
http://forums.usfirst.org/showthread.php?t=11660
Unread 01-02-2009, 15:26
Pausert Pausert is offline
FRC #1727 (REX)
Team Role: Leadership
Rookie Year: 2007
Pausert is an unknown quantity at this point
I am also having the same problem as the original poster. The code downloads successfully and the Driver Station says it has code, but the Jaguar's lights do not become constant and no pwm output occurs.
One of our mentors laptops can load the code and have it work though. I have checked that all our build settings and code are the same, but nothing seems to be wrong.
Unread 01-02-2009, 17:23
rpcoe rpcoe is offline
FRC #0028
Rookie Year: 2007
rpcoe is an unknown quantity at this point
We had similar problems until we carefully read the "readme" file. You have to re-image the CRIO to the latest version included with the update 3/
Rob
Problem deploying/running default code blaxbb FRC Control System 0 10-01-2009 11:59
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Problems with Kevin's 2007 default code bruss6 Programming 8 19-01-2007 15:42
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
