Go to Post Gracious professionalism is a two-way street. - Bharat Nain [more]
Unread 31-01-2009, 18:47
Robopanda6 Robopanda6 is offline
FRC #2477
Robopanda6 is an unknown quantity at this point
Adjusting Camera Code to get Better Image
Does anyone know a procedure to improve the image to track the colors given to track on the top of the trailor?
If so how do you adjust settings and what do you adjust?
It would really help if someone responded>_<
Thank YOU
Position idlers to get better chain wrap -- a question about good practices. Madison Technical Discussion 23 31-01-2008 09:35
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
For anyone who doesn't get the camera code..... Jake M Programming 8 16-01-2006 18:56
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Adjusting Sensitivity/Scale of Controls archimedes Control System 6 14-01-2005 10:30
