Go to Post Cooperate BEHIND the curtain; compete IN FRONT OF it. - Travis Hoffman [more]
Unread 31-01-2009, 20:17
zrop zrop is offline
FRC #2526
zrop has a spectacular aura aboutzrop has a spectacular aura aboutzrop has a spectacular aura about
For those who are skeptical about propellers - Team 2526
The props both spin at about 7000 rpm, but they haven't been properly calibrated yet, so we may get quite a bit more power out of them.
Videos:
http://www.youtube.com/watch?v=mlUPGUfgrHo#
http://www.youtube.com/watch?v=crKvPEwvf-U
And for those safety nazis -- why yes we do have a safety cage for it
Unread 01-02-2009, 00:14
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Re: For those who are skeptical about propellers - Team 2526
What type of props are those? They look like 9"x something. Are they balanced? If not, I can tell you how to balance a prop.
Also, I'm not quite sure that that cage is going to be enough. I'd put another layer on on top or underneath so that the area of each open area is divided into four areas--if the props do explode, I'm pretty sure they could get through the pictured version. Reducing the open area will also reduce the risks.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 01-02-2009, 00:22
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Wow that totally is a unique and different propulsion system! I cant wait to see that in actual competition!
I would tend to agree with Eric though, I'd add some more protection to that cage. The cage will protect from reaching hands, but if those props were to ever break, (and going 7000 rpm, they very well might) you dont want blades going flying... I'm not a safety Nazi, I just like being safe.
Overall though, Awesome!
Unread 01-02-2009, 00:28
FRC #2526
safety cage we are going to use is designed to keep balls outs rather than keeping blade shrapnel in.
Unread 01-02-2009, 00:41
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
The inspectors will be looking for both. One piece of prop shrapnel gets through, and <S01> is probably going to be called. Then you have to remove both.
Let's say those are 9" blades going at 7000 RPM. That's C=pi*d=pi*9=28.26" per revolution. That's about a 2' circumference (rounded down to emphasize the need for protection here). So, the tips of that prop are traveling at 7000RPM=116.7RPS over a 2' circle. That's a tangential speed of 233.3 feet per second--or about 4 FRC fields in one second. If a tip breaks off at that speed, you WILL get a safety violation if it leaves the robot! And, if I were the head ref, I'd make you either remove the props or add protection to the cage. Play it safe and add material now.
Edit: I just saw this: http://www.chiefdelphi.com/forums/sh...049#post812049
I would consider this, or something similar, much safer than your current setup.
Past teams:
Unread 01-02-2009, 00:44
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
What you should do is put them up high, so they will both propel your bot and blow-away balls.
If it can move a 120 lb. bot it should be able to deflect a few rocks
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 01-02-2009, 00:49
Greg Peshek Greg Peshek is offline
FLL #2054
Rookie Year: 2011
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Sadly that hasn't worked with the tests our team has doen, the porous nature of the ball's geometry tends to not move it at all. Our tests were all done with a 22" blade with a 3D-10A pitch blade that was moving a lot of air at a 1:1 ratio from a CIM. YMMV.
Looking good guys, keep it up.
-Greg
Unread 01-02-2009, 00:59
FRC #2526
-Greg
Yeah, that's why we have a 3.5 multiplier on our props. So the 2.5 k rpms you get on a CIM motor at peak power output you don't have nearly enough pushing power. Our props are actually push them at about a walking pace.
See, ideally you reach 88% - 94% the speed of sound on the tips of your props in order to get maximum power.
Unread 01-02-2009, 01:09
FLL #2054
Rookie Year: 2011
Well, our blade/s pull too much power to gear it up any. We start tripping a 40A breaker at a 1:2 ratio. The size of our prop combined with the really high pitch, and the fact that the blade is cut to give a lot of thrust in one direction.. gave us a pretty good acceleration to around the speed you're describing at 3/4 ratio.
Of course we're going for different things. You have them for turning and maneuvering plus a good amount of power. And we're going for sheer power, mainly for getting across in a straight line fast, pinning, and then dumping.
Tell you what, you make it to Atlanta for Championships, we'll have an Overdrive style race.
-Greg
Unread 01-02-2009, 01:15
FRC #2526
-Greg
You might want to reduce your pitch then. High pitches are made for high speeds, therefore you're being really ineffective and ideally you'd have about 1-2 pitch prop from max speeds of about 7-15 mph. Otherwise, even with our pitch of 3.75, we hit ideal speeds at about 30 mph.
And yes, prop race at Atlanta ;D
Unread 01-02-2009, 01:22
XaulZan11's Avatar
XaulZan11 XaulZan11 is online now
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Yes, the cage does make it more safe, but why isn't it on during testing? In the 2nd video, I think the person bending down gets a little too close; one slip and people will be watching the video for different reasons...
Creative design, but make sure it's safe
Unread 01-02-2009, 01:26
FRC #2526
Haha. It just looks like I got close, but really, i grabbed it about a foot in front of the props. And as for the cage, we didn't have the mounting brackets completed at the time of testing... and we were anxious.
Unread 01-02-2009, 10:10
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Interesting
Unread 02-02-2009, 15:13
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
no team (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Good, intresting design, but i have one question. Isn't there a rule about the wheels being parallel to each other? In the one picture you can clearly see how the frontwheels turn with the propelers while the back wheels just stay stationary. Is this still legal? From how i read it and heard, it doesn't seem legal.
  #15   Spotlight this post!
Unread 02-02-2009, 15:15
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
You're thinking of <R06>, which specifies that the axis of rotation of the wheel must be parallel to the floor. It doesn't say anything about the axis of rotation of the axis of rotation.
Past teams:
Fans/Propellers - Are you doing them? Greg Peshek General Forum 15 06-02-2009 19:50
To those who are officers/admins here... synth3tk General Forum 3 26-09-2008 07:06
For those who lack dedication... Pi Is Exactly 3 Regional Competitions 19 09-02-2005 21:26
Some good humour for those who are bored. Frank(Aflak) Chit-Chat 0 09-12-2003 19:11
For those who were wondering... Nate Smith Championship Event 2 22-04-2002 17:25
