Go to Post The more you cling to the misfortunes that have already befallen you, the less you'll be able move forward from here. - Kevin Sevcik [more]
Unread 01-02-2009, 17:19
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
Temporary deployments
I've been having trouble with the "run as startup" deployment not being non-volatile; when I shut the robot off and start it up later, it doesn't start the Labview Real-Time engine. I was originally having trouble with our first cRIO, but I haven't recently. I'm currently using our second cRIO, which has only been in use for a week.
Also, one of the volatile deployment methods deploys, but doesn't run either. It's the method where you right-click on "Robot Main.vi" and select "Deploy" from the menu.
Thanks!
-- Marshal Horn
Temporary Answer to No Spell Check Clark Gilbert CD Forum Support 4 04-03-2004 14:18
Temporary Site Jack FIRST Scouting Network 11 12-06-2003 23:39
Temporary Panic Nate Smith Chit-Chat 1 01-06-2001 11:20
