Go to Post But if we just re-play "Triple Play" then what in the world will the Game Design Committee do with all that new-found free time? Since they wouldn't have to come up with a new game, they would have to concentrate on other things - like how to enforce the proposed "no metal on robots" rule. - dlavery [more]
Unread 01-02-2009, 19:57
SamRI SamRI is offline
FRC #2443
SamRI is an unknown quantity at this point
More Problem With Accelerometer
We are having problems getting our accelerometer to work consistently. It works then when we run our program again it stops, then its starts work after another restart. Could it be LabView or our accelerometer?
Please post on Imaginary Animals Post
Unread 01-02-2009, 19:59
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: More Problem With Accelerometer
Since the accelerometer is an analog sensor, it should not be the issue. I have to say it's a LabView issue.
It could be the accelerometer, but it's not very likely.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 01-02-2009, 20:07
FRC #2443
Can you please explain a little more
Unread 01-02-2009, 21:08
RyanN's Avatar
RyanN
What do you want me to explain?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 01-02-2009, 21:14
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What exactly do "works" and "stops" mean here? How are you using the sensor? What code are you running to read it?
Unread 01-02-2009, 22:27
FRC #2443
Ok So when we First start up our robot we get normal results
after a couple of minutes if stops giving us readings
Unread 01-02-2009, 22:31
RyanN's Avatar
RyanN
Try hooking up a potentiometer and see if the readings stop working after a few minutes as well.
If the potentiometer continues giving a good reading, then your accelerometer is broken. If the potentiometer stops working after a few minutes, then it's a programming issue or a more serious issue with the cRIO.
Without anyone here knowing exactly what you're trying and without more details, we cannot really help.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
Help with accelerometer. ThisIsFood NI LabVIEW 6 17-01-2009 12:40
URGENT! We need help with the accelerometer lkdjm Electrical 5 11-02-2005 16:42
Using Accelerometer with '04 controller sanddrag Control System 4 20-02-2004 12:18
