Go to Post When the world gives you lemons make lemonade serve it at your press conference to expand the program. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 02-02-2009, 00:29
fdelagarza fdelagarza is offline
FRC #2122
fdelagarza is an unknown quantity at this point
Smile code example to set 4x encoder decoding mode mode
Hello,
Now with the third update the 4x mode encoder decoding should be working, I have been testing our robot encoders and it sems that the default constructor, which by default should select 4x is using 1x mode after comparing the counts with the distance
i am using this code to create the encoders:
m_baseLeftWheelEnc = new Encoder(1, 2, false);
m_baseLeftWheelEnc->Encoder::Start();
m_baseRightWheelEnc = new Encoder(3, 4, true);
m_baseRightWheelEnc->Encoder::Start();
Could you post an example of 4x encoders configuration code
Thanks
Code error causing robot to go into programming mode. MJD Programming 14 30-10-2007 14:21
FRC Camera code in YCrCb Mode? Terry Sherman Programming 9 25-01-2006 16:43
Where to insert code Autonomous mode caderader Programming 5 18-02-2005 16:49
Anybody have a code for an autonomous mode to go to the 50 point bar???? and... chaoticprout Programming 9 06-11-2004 12:22
Simple Autonomous Mode Example deltacoder1020 Programming 5 08-03-2004 20:22
