Go to Post If you're doing it to win, you're doing it wrong. Teams who truly understand why they are doing what they do will win Chairman's simply as a result, an added benefit. The award isn't the goal. It's the impact you create, and the results you see. - dcarr [more]
Unread 02-02-2009, 12:30
Tom Bottiglieri Tom Bottiglieri is offline
Custom User Title
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Send a message via AIM to Tom Bottiglieri
TrackTwoColors execution time
It seems (at least in our tests) that the TrackTwoColors function from the example two color tracking code is bogging down the cRIO to an almost unusable point. Has anyone else had this issue?
Symptoms are as follows:
1) When function is called in sequence with motor control code, execution of the main loop is slowed to a few Hz, lagging operator control.
2) Code runs relatively quick when there are no HSL color matches in view. As soon as a pink or green target appears, regardless of orientation, the process slows down immensely. This makes sense, but the lag seems very big for the amount of code that is running.
To fix #1, we split the object matching code out into a separate thread, which fixed the motor update lag. Unfortunately, our servos now overshoot the target by quite a bit before the "target found" flag is raised.
We tried to characterize the execution time of the code block, and came up with the attached graph. I don't have the source on hand, but it looked something like this:
Code:
/*This runs in a seperate thread, so I have no idea how the other threads effect execution time.*/
Timer timer;
float start,finish,delta;
timer.Start();
while(1){
   start = timer.Get();
   TrackTwoColors(params here);
   finish = timer.Get();
   delta = finish - start;
   cout << start << "," << delta << endl ;
A graph generated from the stdout is attached. The low points happen when the camera is panning with no target, and the peaks occur when the target is upside down. The high holds occur when the target is oriented the correct way.
Is there any kind of hidden debug stuff going on? I have turned down all the do-debug flags in target.h, but I don't see a difference. I don't want to re-write a signal processor, and want to make sure I'm not alone before I start any such work.
Link to graph: http://i43.tinypic.com/119w6k9.png
Team 254 | San Jose, CA | Mentor (2010 - Present)
Team 125 | Boston, MA | College Student (2007 - 2011)
Team 195 | Southington, CT | Student (2002 - 2006)
Single button function execution RonStoppable102 Programming 2 05-01-2007 09:45
User Processor Execution Time Andrew Blair Programming 1 12-02-2006 21:52
Loop execution time for Autonomous code Transporter08 Programming 2 13-02-2005 16:17
How to measure execution time? And code size? gnormhurst Programming 17 17-02-2004 08:06
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
