Go to Post All I know is that last year in Philadelphi, our camera locked dead onto MOE (Team 365) and their flourescent green shirts during the matches. They might want to consider what would happen if they get pelted with balls during the autonomous period! :ahh: - Greg Marra [more]
Unread 02-02-2009, 15:34
SamRI SamRI is offline
FRC #2443
SamRI is an unknown quantity at this point
Microswitch 2009
Does anyone know how to connect the microswitch sensor you get in the 2009 kit
Unread 02-02-2009, 16:27
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Microswitch 2009
Connect it between the ground and signal pins of a Digital I/O. The Digital Sidecar's built-in pullup resistor will provide a logic 1 on the input when the switch is open, and closing the switch will give a logic 0. There is a Common terminal on the switch; wire that to ground. Use either the Normally Open or the Normally Closed terminal as the signal, depending on whether you want the switch to close or to open when activated.
2009 Teams Tomatosoup General Forum 2 22-12-2008 11:58
FIRSTBase 2009 tanmaker General Forum 9 09-11-2008 01:30
2009 Registration Greg Needel Regional Competitions 64 15-10-2008 21:49
Microswitch problem SoD Programming 15 01-02-2007 11:55
