Go to Post So basically, the advantage of #35 is that it allows you to be sloppier in your design and fabrication. If you pay close attention to these details, you will never have a problem with #25 chain. - Jim Zondag [more]
Unread 02-02-2009, 16:14
shobuda999 shobuda999 is offline
None #1995
shobuda999 is an unknown quantity at this point
No RSL on Digital Sidecar
Hi Everyone,
Our team is having a serious problem. our RSL is not lighting up at all. We have ran through the benchtop test, and had everything working wirelessly. We have all the latest Labview updates and have successfully deployed the default code. We have the most recent DS update. When we put our hardware into our robot however we noticed our PWM's aren't getting a signal. After doing some research I realized that our digital side car didn't have the robot status light illuminated at all. We switched it out with the other board in the kit, but we are having the same results. We're beginning to worry that the CRio is dead. All the power lights are on solid green, and we have the board connected to slot four of the CRIO. Has anyone experienced this?
Unread 03-02-2009, 08:27
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: No RSL on Digital Sidecar
It's unlikely, but your Digital I/O module or 37-pin cable might be faulty. Try the other cable, and try moving the other Digital I/O module from slot 6 to slot 4.
You said you did the benchtop test. Did the PWM outputs work then? When you say you deployed the "default code", what code are you referring to?
Unread 03-02-2009, 10:58
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
I agree with Alan. If the DSC is getting power but the RSL isn't doing _anything_, you probably don't have the cable to the cRIO working as intended.
Double check that it is in there nicely, and if that doesn't help beep it out with a multimeter (or use a known good cable).
There is a safety "enable/disable" line on the cable that will shut down the entire DSC if it is not connected which would result in similar symptoms.
Unread 06-02-2009, 16:18
None #1995
All the power lights are working on the DSC, but we still have no RSL. I switched out the cable, we are still having the same issue. Our PWM's did work during the benchtop test. By default code I mean the code that is downloaded when you reimage the CRIO, as well as the basic template from Labview.
Thank you all for your suggestions.
Unread 06-02-2009, 18:10
Software Architect
Grasping at straws here...is the Digital Sidecar connected to the NI module residing in slot 4 of the cRIO?
The control system this year is complex enough that it's difficult to diagnose unobvious problems without seeing all the connections. Can you post pictures of the DSC power lights, the RSL pins, and both ends of the cable to the Digital module in the cRIO?
Unread 06-02-2009, 20:12
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
I think there is a manufacturing problem, We helped during Beta testing and the side cars had problems then. We have been using a digital sidecar for four weeks when it all of sudden went bad and no longer works. We are our second one and it is currently working,with no changes in wiring, but for how long? If there is a defect who do we need to bring this to the attention of? We will ordering two more digital sidecars soon.
Faridodin "Fredi" Lajvardi KD7WKD
Unread 07-02-2009, 09:22
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Falconmaster,
What issues did you encounter during beta testing? I wasn't aware of any issues being uncovered other than an interference between the case and an unrelated capacitor. We're not aware of any other design issues with the DSC.
Shobuda999,
The fact that BOTH of your Digital Sidecars have the same issue leads me to believe that they're not defective. Of course, it's always statistically possible that you received 2 bad modules. Or maybe they were assembled back-to-back when a surface mount part ran out during pick-and-place?
From what I can tell, other teams' RSLs are working just fine. Is the little green LED on the circuit board lighting up at any time?
http://decibel.ni.com/content/docs/DOC-3120
The module as an overcurrent protection device to keep shorts on the RSL output from getting exciting. You might want to plug your light directly into a protected 12V supply (eg 20A breaker on the PD) and confirm that your light is OK.
Russ
Unread 07-02-2009, 11:50
AKA: Ledge
Team Role: Teacher
Russ
During Beta testing the quality control or manufacturing process required us to send back components to be fixed.
On the digital side cars
One team, Camelback High School, had it working briefly then it went out, no longer functioning and no green light on the power indicator. They swapped it out for their spare, having made no wiring modifications and it is now working.
Another team. Maryvalle High School, their first one was working and then all of a sudden, having done nothing at all, it stopped working, the green power light is on continuously with no blinking. Their second one was then installed and the green light does not come on at all.
Ours, team 842, was working for four weeks and then stopped working for no reason at all. We swapped the second one in having made no wiring changes and it is working fine.
This series of malfunction might not prove that is is defective, but it looks awfully suspicious. We are going to buy two more sidecars for when the next one goes out.
If you can shed any light on this we would be eternally grateful.
Unread 07-02-2009, 23:06
I'd love to get my hands on the faulty sidecars. If you send them back to AndyMark, they may actually get to me or someone else who can dig deeper. The boards aren't really complicated but it's impossible to identify the specific failure without having them in our hands.
Will you be sending them to AndyMark for repair or replacement? Or could you send them to me for failure analysis?
Russ
Unread 07-02-2009, 23:38
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
A picture of a repeating defect is posted in media.
http://www.chiefdelphi.com/media/photos/32662?
Unread 08-02-2009, 08:19
That's a known issue that, I thought, FIRST had already disclosed to teams. The C6 capacitor is not related to the RSL in any way (unless it works its way over to the circuitry and causes a short through the conformal coating that's on the board to protect it from such issues).
http://forums.usfirst.org/showthread...ight=capacitor
Russ
Unread 03-02-2009, 10:47
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Are you talking about the lights on the DSC?
if not...
be sure you have the 12v input on the DSC powered. We forgot to do this once and had the same symptoms...
Digital Sidecar Problems cabbagekid2 FRC Control System 13 31-01-2009 17:23
Digital Sidecar Not Working tseres Electrical 9 31-01-2009 17:22
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
Fusing for Digital Sidecar (was: HIZZELP) KilroyLaxer FRC Control System 4 15-12-2008 20:44
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
