Go to Post You should qualify the same way you eliminate if you ask me. - sircedric4 [more]
Unread 02-02-2009, 17:02
xc4life's Avatar
xc4life xc4life is offline
xc4life
FRC #2509 (Hutchinson Tigerbots)
xc4life is an unknown quantity at this point
QUESTION: SubVI's, and incorporating camera files
Okay, the deal is that we are attempting to incorporate our camera VI's that we have created into our main robot project.
I think that there are two approaches. Apparently one is to reference the camera VI within the RobotMain VI using a sub VI and connector pane. The other, which I personally think would be more efficient would to be simply copying and pasting the camera files directly into the RobotMain folder. The problem we are trying to overcome is creating a single robot project that contains both the drive VI's and the Camera VI's. We tried to update the cRIO with each project separately, but each time we do this, one project overwrites the other.
Any ideas? How can we incorporate the two projects, or at least the VI's within each?
“Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it.” -Sir Henry Royce
Batch files to switch between DHCP and Static IP DtD Programming 9 28-01-2010 14:27
Need Help Locating .h and .cpp files jkjohnson Programming 0 30-01-2009 09:00
Converting step files to inventor files GMAdan Inventor 4 01-01-2007 20:09
Camera CAD files hopkins Inventor 1 12-03-2005 10:38
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
