Go to Post CD is a forum provided by a group of people. You use it with their permission. Don't like it? Don't use it. - Andrew Schreiber [more]
Unread 02-02-2009, 18:23
M. Gildner's Avatar
M. Gildner M. Gildner is offline
College Mentor
AKA: Matt
FRC #2620 (Servos)
M. Gildner is on a distinguished road
Driver Station S.O.S.
Ya our driver station is messed up. When we attempted to do the benchtop test it didn't even go through its boot up sequence it just sat there with a blue screen. No symbols or anything on the screen, just blue.
WHAT IS GOING ON
Servbot?...
SERVBOT!!!
Unread 02-02-2009, 19:40
gaby1367 gaby1367 is offline
Driver (Ret.)
AKA: Pablo
FRC #0714
gaby1367 is an unknown quantity at this point
Re: Driver Station S.O.S.
i asume you guys waited for it to load and it didnt
how long did you guys wait?
Is it plugged in correctly? (power wise)
Did you guys droped it?
jk if it dosent boot up its defective get a new one.
Unread 02-02-2009, 19:47
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Make sure your driver station inputs are not going from +5 volts directly to ground. this will short it out and will be stuck at that screen. Try unplugging the power source and then unplug all of the inputs. once you have unplugged them all, plug your power source back in and see if it will boot.
I'm right 90% of the time, so why worry about the other 3%?
Unread 03-02-2009, 10:57
Jason Joye Jason Joye is offline
FRC #0226 (TEC CReW Hammerheads)
Jason Joye will become famous soon enough
You could try reflashing the DS as mentioned here:
http://forums.usfirst.org/showthread.php?p=22389
_____________
"Success is going from failure to failure without loss of enthusiasm" - Sir Winston Churchill
Unread 04-02-2009, 16:08
M. Gildner's Avatar
College Mentor
AKA: Matt
FRC #2620 (Servos)
Solved via overnight shipping (Andymark).
Servbot?...
SERVBOT!!!
Unread 18-11-2009, 16:00
AMFof306 AMFof306 is offline
FRC #0306
AMFof306 is an unknown quantity at this point
Exclamation Re: Driver Station S.O.S.
Hi I'm from team 306 we have a problem with our Drivers Station, Ethernet port 2 of it is broken and I need to know if there is a way to work around it or if we are going to have to get another one.
Unread 18-11-2009, 16:09
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
You only need one working ethernet port on the Driver Station, but you do need at least one, so protect it.
Just connect the Driver Station to your router and anything else to the router.
Unread 18-11-2009, 18:20
wilmo's Avatar
wilmo wilmo is offline
FRC #0868 (TechHOUNDS)
Team Role: Leadership
wilmo will become famous soon enough
We've gone through our share of DS too. Try plugging a short male-female Ethernet cable into the one port still working and plug your extensions into the female end. The ports on the DS seem to fail after being wiggled too much from attaching/detaching Ethernet cables.
Unread 18-11-2009, 18:34
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
If your DS is actually toast, try the Virtual DS Dave Flowerday created:
http://www.pier13.com/projects/frc/virtualds/
CD Thread: http://www.chiefdelphi.com/forums/sh...ght=virtual+ds
Many people have found it very useful when they need a Driver Station but don't have one handy (or don't feel like buying another).
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 20-11-2009, 16:08
FRC #0306
Thanks guys I'll try the router thing and if that doesn't work I'll just use the Virtual DS but will there be a new driver station for veteran teams this year if the router use doesn't work?
Unread 20-11-2009, 16:28
Chris is me's Avatar
AKA: Pinecone
Yes, all teams will get a DS next year. It'll actually be a small computer (the Classmate PC).
Unread 28-11-2009, 17:17
ironbears ironbears is offline
Alex@854
AKA: Alex
FRC #0854 (Ironbears Team 854)
ironbears is on a distinguished road
We had the exact same problem on our DS. so i decided to open it up and see the problem, the ribon connector was loose, so I reattached it. As well the Ethernet Port was torn off and must of been disposed, so now im looking for a replacement. Hopefully there are replacements in the KOP.
Iron Bears Team 854
Rookie Year 2002
2008 ON Xerox Creativity
2007 WAT Rockwell Automation Innovation in Control
2007 WAT Regional Finalist
2007 ON Motorola Quality
2007 ON Regional Finalist
2006 ON Motorola Quality
2005 ON RadioShack Innovation in Control Award
2005 WAT RadioShack Innovation in Control Award
2003 ON Delphi "Driving Tomorrow's Technology"
2005 The Championship Event (4/21/2005 - 4/23/2005)
2003 The Championship Event (4/10/2003 - 4/12/2003)
Unread 28-11-2009, 19:35
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Rookie Year: 2007
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
You can buy a 2009 DS at Andymark.
http://www.andymark.biz/am-0269.html
However with the new classmates coming as our driver stations I don't think we'll be seeing that blue box anymore.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Need Driver Station dekker120 FRC Control System 2 02-02-2009 12:59
Driver Station Input SwampDogs NI LabVIEW 3 27-01-2009 11:33
Connections to Driver Station Zellboy Electrical 1 23-01-2009 16:24
Driver Station Login Mr-Shutter FRC Control System 2 12-01-2009 23:36
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
