Go to Post Cut it out with the paper airplanes! Frank hath spoken! - cgmv123 [more]
Unread 02-02-2009, 22:35
Devo1098 Devo1098 is offline
FRC #1098
Devo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really nice
pic: 1098 Steering 2009
Unread 02-02-2009, 22:36
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Re: pic: 1098 Steering 2009
Looks cool! be sure to keep your CG LOW with this beast, it looks tippy! With the inside wheels so close together, it may want to fall over to that side...
Former Mentor Team 1771
Former mentor Team 4509
Unread 03-02-2009, 08:08
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
Thanks for your thoughts. I am a mentor on 1098. This bot has a very low CG. The team is planning on adding weight low on the chassis as well. They are expecting to be about 20 to 30 pounds under weight. The chassis does seems very stable right now.
Unread 03-02-2009, 08:15
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Is there a separate motor on each wheel?
Unread 03-02-2009, 17:36
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
we considered a design nearly exactly like this. seems like a pretty simple way to get 4 wheel steering. We ended up weighing the options and went with a 4 wheel ackermann style steering system. very similar steering benefits but a bit more stable since the wheels don't get too close together.
good luck with the design - i hope it works well for you.
Unread 04-02-2009, 02:31
bmarick bmarick is offline
FRC #2374 (Crusader Bots)
Rookie Year: 2007
bmarick is on a distinguished road
it is interesting seeing this idea put to use.
It was an option that our team decided against (this style) due to the tipping chance. good luck
Brandon
pic: 1098: Back To The Future Devo1098 Extra Discussion 32 10-04-2008 11:35
pic: steering edomus Extra Discussion 10 05-06-2005 11:12
pic: Steering mechanism jskene Robot Showcase 16 17-02-2005 23:20
pic: BHD1 - For team 1098 2005 Animation CD47-Bot Extra Discussion 1 15-03-2004 20:53
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
