Go to Post Thanks and don't stay up all night waiting for Lavery Claus! - Beth Sweet [more]
Unread 03-02-2009, 03:09
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Camera power/comm problems disable the DSC
I haven't seen this posted before, but I ran into this problem today.
I had been testing traction control which did not enable the camera. I switched to run the 2 color example and the DSC would not go enabled. The download completed correctly, the DS said enabled and Dashboard said enabled, but the DSC was giving a slow blink that the NI documentation says means that the cRIO is disabled. After some debugging, I found that the power connector for the camera had come loose. I plugged it in, the camera came ready, and the DSC went enabled. After some further testing, I found that and power or comm problem with the camera will disable the DSC. I don't believe that this is the intended mode of operation. Losing power or comm with the camera should not shut down the robot.
I'm going to post this on the FIRST fourms as well.
Also note that the battery voltage was showing on the DS and in Dashboard. It looks like cRIO doesn't go enabled until the camera is operational.
Last edited by rwood359 : 03-02-2009 at 06:28. Reason: addition of Battery voltage
Problems With The Power Distribution Block sanddrag Electrical 26 27-03-2007 23:11
PROBLEMS WITH THE CAMERA RDD Programming 2 18-02-2007 15:12
again, problems with the camera razer Programming 4 02-02-2007 11:50
power to the camera masanchez General Forum 1 23-01-2006 20:16
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
