Go to Post The game is as much a competition of strategies as it is of robots. There is never any one "best strategy." If teams choose to use this as their strategy, find one that will beat them. - srjjs [more]
Unread 03-02-2009, 04:32
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
using digital inputs from the driver station
I'm not sure exactly how to utilize them.
I know that the Driver Station Get dig In samples all of the digital inputs....
but do you have to insert the values into an array before you can see if a certain switch hooked up to the driver station is sending true or false, and if so... how do you do that?
Basically, I am trying to have a switch on the driver station return true or false, but I have found that u can't wire the Driver Station GetDig In directly to a conditional.
Any help would be greatly appreciated. Thanks.
Programming Digital Inputs from Driver Station spooncwru Programming 8 01-02-2009 13:14
LabVIEW - Analog inputs from driver station lag? RedOctober45 NI LabVIEW 1 30-01-2009 10:39
Digital Outputs on the Driver Station with C/C++ Bongle C/C++ 6 26-01-2009 15:45
Using driver station digital inputs Japper FRC Control System 6 19-01-2009 20:01
Using Analog Inputs as Digital (on the OI) Guy Davidson Control System 16 10-03-2008 17:17
