Go to Post mabye this is a case of I AM JVN to the Extreme! - Tytus Gerrish [more]
Unread 03-02-2009, 12:00
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Trouble Reading Drivers Station Digital Inputs
I'm finding that reading the drivers station digital inputs is unreliable. Our switch panel isn't ready yet so I am tying the signal pin of port 8 directly to the +5 pin. This should avoid the lack of a pull up or pull down problem on the digital inputs.
I'm using the iterativeRobot class. When I call the drivers station method
Code:
value = m_ds->GetDigitalIn(8);
I usually get a one value returned but sometimes I get a zero.
I notice that IterativeRobot class is synchronized to the drivers station packet. But the DriversStation access methods all do a GetData() call. It looks like GetData does a wait for a new packet although the comment says that it doesn't.
Has anyone seen this?
using digital inputs from the driver station SL8 NI LabVIEW 2 04-02-2009 15:53
Programming Digital Inputs from Driver Station spooncwru Programming 8 01-02-2009 13:14
reading multiple digital inputs angelkat Programming 2 25-01-2009 00:22
Using driver station digital inputs Japper FRC Control System 6 19-01-2009 20:01
Reading NES controller from digital inputs bear24rw Programming 10 07-04-2007 01:17
