Go to Post I think rovers on Mars are way cool but you won't get a crowd of enthusiastic participants cheering as they trudge 150 meters a day. - Andrew Schuetze [more]
Unread 03-02-2009, 14:51
TheGreaterNate TheGreaterNate is offline
FRC #2975
TheGreaterNate is an unknown quantity at this point
Robot Width
We're a rookie team and made a bit of a mistake in our design. Our chassis is exactly 28" wide. The problem is, there are a few bolt heads sticking out beyond the 28". Are there any tolerances with the measurement? Our bumbers will still fit flush against the robot.
I've tried posting this to the Q & A, but I can't seem to get permission to post with my account.
Unread 03-02-2009, 14:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Width
The sizing box is exactly 28" inside, so your robot probably won't fit in it. Can you countersink the bolt holes, and use flat head bolts? or possibly shorten the frame members and put it back together an inch or two smaller?
Unread 03-02-2009, 14:56
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: Robot Width
As Jim said, there is absolutely no flexibility in the 28" measurement (or the 38" and 60" measurements for that matter)
A couple suggestions:
-Try a countersink/counterbore if possible, it will require the least amount of reconfiguration of your design
-Is a rivet head small enough that by switching to rivets your in the mark?
Lesson learned: build your bot slightly under the dimensions. We build ours half an inch under in each dimension.
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 03-02-2009, 15:11
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Robot Width
Not only bolt heads cause problems. If you build too close to max dimensions the inevitable "slightly out of square" will put you over the limit.
We always build at least an inch under, just in case.
Unread 03-02-2009, 15:19
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: Robot Width
As a mentor, I would like to say that this team has the opportunity to learn a valuable lesson: always design with margin. You will need to fix your robot, but more importantly, remember this general lesson in coming years.
Unread 04-02-2009, 07:07
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2000
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Robot Width
I agree with Indy Sam, we also try to build 1" under all the given dimensions but our robot seems to grow some.
With monocoque you have to allow for the bends in the aluminum. We didn't. Our bot is only 1/4" under size now
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 04-02-2009, 07:16
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
Re: Robot Width
As the others have stated, there is NO TOLERANCE at all on the dimensions, and your robot will also NOT be perfectly square which will eat up a little of the width.
We were in the exact same position you are in our rookie year with team 1858. Unfortunately we did not find it out until we were in inspection!! Save yourself a lot of grief and do whatever you have to and fix it now!
Unread 04-02-2009, 08:33
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Robot Width
Nate,
As stated above the sizing box is a physical limit on size. Inspectors have no options on this critical issue. Weight and size are the first things checked during the inspection process, followed by bumpers. If you would like to PM me, I could offer some suggestions depending on what material your structure is assembled from and what the hardware is used for. As you can see, many of the experienced teams, build to specified dimension less at least 1/4" as two objects cannot occupy the same space at the same time (robot and sizing box wall). If you are using tubing, it is a simple matter of drilling a larger hole in the outside of the tube and moving the bolt head to the inside. If your bolts are used for mounting sheet material (aluminum or lexan) you may be able to use rivets and stay within the dimensions. Or you may be able to move the sheet to the inside of the frame. It is better to take care of this before ship, instead of during inspection.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 03-02-2009, 14:55
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Robot Width
You will have to reduce the width. During inspection the robot is placed inside a box like structure. All parts must fit inside this structure.
What you are learning is to build your robot at least 1/2" under size to allow for the bolts and other protrusions.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 04-02-2009, 08:25
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Robot Width
As others have said, the tolerance is 28" MAXIMUM. In other words, you will have to rework your chassis. But better to find out now than on the Thursday of the competition.
Also, the only account that can post questions on the Q&A is the username and password given to you by FIRST on the team information (TIMS) site.
Good luck.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 04-02-2009, 09:39
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Team Role: Teacher
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Re: Robot Width
Since everyone else handled the dimension issue, let me address this one (since I've been there myself). You need to get your Q&A password from the TIMS system. That will allow you to post questions on the FIRST forum. Without the account and password, you'll be facing gobs of frustration with Q&A.
PM me if you need additional instructions on this.
"It's NOT Just A Robot Thing!"
Unread 04-02-2009, 15:53
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: Robot Width
And don't feel too bad... there were a few experienced teams having trouble with the sizing box in Atlanta last year. Things twist, bend and get repaired during the competitions and... well we try to work on a 27"x37" robot if we can and always try to finish a few pounds under weight.
Jason
Unread 04-02-2009, 21:23
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
Re: Robot Width
My experience is use a 26x36 bot. It always fits.
A couple of suggestions for reducing this that wasn't mentioned above:
1. Weld, who needs bolts?
2. Instead of bolting directly, use two plates(also angle work in a similar way). One on top and one bottom. Bolt the two members that are currently bolted to the plates instead. That will give you a good durability without extending outward.
The first is ideal if you have the ability, the second is a quick fix that may add a few pounds but will get the job done with relative ease.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 04-02-2009, 22:46
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: Robot Width
One thing that must be considered is your BUMPER PERIMETER (which is defined by a string wrapped around your frame). Due to the rules this year, robots cannot extend beyond their BUMPER PERIMETER at any time during a match.
This simply means that while your frame can be less than your maximum dimensions, its size also determines how big the REST of your robot can be horizontally.
  #15   Spotlight this post!
Unread 04-02-2009, 23:52
MrForbes's Avatar
AKA: Jim
Re: Robot Width
That's what we thought, until last year....our robot was about 27" wide near the top, and it poked outside the sizing box. The best part is that when we turned the robot around, it poked out the same side of the sizing box at the top.
Yup, the sizing box was not square.
Lesson learned: make the top considerably smaller than the bottom.
(we always start at 26 x 36 but it seems to grow a bit)
Width vs Length Magnechu Technical Discussion 4 07-01-2009 21:33
Can you "flip" your robot to give you a 60" width? Beamer159 Rules/Strategy 11 09-01-2008 21:12
axel hole width Booger Technical Discussion 1 17-07-2006 16:29
Measuring a Pulse Width MikeDubreuil Programming 22 21-07-2005 10:22
Bridge Width Question archiver 2001 3 23-06-2002 22:54
