Go to Post So we are able to run a very competitive and active robotics program. Sustainability, alas, is a month-to-month issue for us and is dictated by the space situation. This is okay today. Tomorrow could be different. We live like this. - Clem1640 [more]
Unread 03-02-2009, 16:27
VeedotJaydot VeedotJaydot is offline
FRC #1379
VeedotJaydot is an unknown quantity at this point
[FTC]: USB controler problems
We have been programming our robot for FTC and so far, we haven't been able to make the robot to respond to the USB controller through the bluetooth network with the robot. We have set the bluetooth network up to the robot academy tutorial's standards, we also have calibrated the controller and made sure it is working properly. We may have coded it wrong, but even the default code Here(2 Joystick Drive Program) won't respond when we use the controller. Long story short, are there special VIs that are needed for use of the controller, or is there some other possibility that I'm over looking or I'm ignorant of?
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
First problems with FTC and Labview PhilBot National Instruments LabVIEW and Data Acquisition 0 10-09-2008 20:21
away around the USB chicklet for using USB Controllers Stobei Programming 2 26-01-2008 14:27
Using a USB Controler Ethulin Control System 8 27-01-2006 21:46
