Go to Post To me, the changing rules are a big part of the fun. If the rules stayed the same year to year, robots would start to look the same. That would be boring. - Richard Wallace [more]
Unread 03-02-2009, 17:14
nate15810's Avatar
nate15810 nate15810 is offline
World's Most Clueless Programmer
FTC #0154 (154 Renegade)
Rookie Year: 2007
nate15810 is an unknown quantity at this point
[FTC]: Toggle controls
Is it possible to toggle the controls?
i have a couple of servos that need it
Unread 03-02-2009, 19:44
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
Re: [FTC]: Toggle controls
Can you provide additional details about what is meant by "toggle the controls?"
Thanks,
Michael
Unread 05-02-2009, 15:33
nate15810's Avatar
Rookie Year: 2007
Push a button...the servo goes there
release the button and it says there
push again and it goes to the starting position
release and it stays there
ex)
animation made by me
Unread 05-02-2009, 16:22
Great animation! Thanks.
Which programming language are you using?
Michael
Unread 05-02-2009, 16:42
nate15810's Avatar
Rookie Year: 2007
Robot C
Unread 05-02-2009, 18:05
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
OK. So what you want is that when u press a button, let's assume button 1, then the servo moves to one position. if you press another button, the servo moves to an original position.
So, the code has is a tad bit more complex.
int sum = 2;
if(joy2Btn(1)) // if button one is pressed
sum = sum +1;
int calcremainder = sum % 2; // This line calculates the remainder of sum/2.
if (calcremainder = 0)
servo[Servo1] = 100;
else
servo[Servo1] = 0;
So the code above basically does this. Each time you hit the button, the program counts it. I know there's an official counter in the program, but i'm ghetto like this.
Then, it takes the number of times the button has been hit, and it divides by 2. So, then the value can either be 0 or 1. So each time you hit the button, the value switches between 0 and 1, so when the value is 0, you have a position, when it is 1 you have a position.
That's the logic.
There might be a better way, but this is one possibly option.
1648: 2013-2014
5283: 2015
Unread 05-02-2009, 18:39
nate15810's Avatar
Rookie Year: 2007
it just makes the arm reverse itself
Unread 05-02-2009, 19:41
Sunny
Rookie Year: 2007
That code above should do what the animation does. But you will have to put in the correct servo values.
1648: 2013-2014
5283: 2015
Unread 06-02-2009, 16:14
nate15810's Avatar
Rookie Year: 2007
yeah, i put that in and reset the servo values, but it just reversed the servo...
here's my code
Code:
int sum = 2;
if(joy2Btn(2)) // if button 2 is pressed
sum = sum +1;
if (calcremainder == 0) <this was an error in your lines...it needed a double=
servo[ServoB] = 100;
else
servo[ServoB] = 0;
Unread 06-02-2009, 16:54
Ethan Spitz Ethan Spitz is offline
President
FRC #3637 (The Daleks)
Team Role: Leadership
Rookie Year: 2011
Ethan Spitz is an unknown quantity at this point
What do you mean it makes the servos reverse themselves?
Also, I don't see how that works if the counter resets itself each time, it wouldn't stay I don't believe
Code:
int touch = 1;
//put variable before while loop
if(joy2Btn(1)) {
   if(touch == 1){
     touch = 0;
   }else{
     touch = 1;
//you may want a really short wait here so when you press the button it does not switch back to original really quick
if(touch == 1){
}else{
  servo[ServoB] = 0;
Unread 06-02-2009, 19:09
Sunny
Rookie Year: 2007
ah yes. The counter would have to be outside the while loop.
That is a basic code.
Now there is an official counter which might be better than actually going in and creating another variable. It probably won't make a huge difference, but whateva you want.
1648: 2013-2014
5283: 2015
Unread 10-02-2009, 14:47
nate15810's Avatar
Rookie Year: 2007
still doesn't do anything
...thanks anaways guys
if you could figure it out, thanks for putting up with me
Unread 10-02-2009, 16:53
nate15810's Avatar
Rookie Year: 2007
found this online, but i tried converting it and with my small ammount of programming knowledge, i didn't get very far
Code:
#include <stdio.h>
int main() {
     int x;
     for (x = 0; x < 10; x++) {
          if(x == 1 || x == 4 ) {
               continue;
          else if(x == 8) {
               break;
          else {
               printf("x = %d", x);
     return (1);
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
toggle switch Windward Programming 31 27-01-2006 22:38
Code: Toggle on Tap Dave Scheck Programming 0 11-02-2005 18:07
Toggle? f22flyboy Programming 5 03-11-2002 08:03
