Go to Post Dean looks rather debonaire in a tux. Like some sort of engineer super hero. The tuxedo is like his Clark Kent costume under which lies his amazing denim suit, to be whipped out at a moments notice in the face of uninspired youth and problems unconquered. - phrontist [more]
Unread 03-02-2009, 17:29
Idan Idan is offline
FRC #1577 (Steampunk)
Idan is an unknown quantity at this point
update #9
Here is the new update
http://www.usfirst.org/uploadedFiles...Update%209.pdf
Unread 03-02-2009, 17:44
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Update #9
http://usfirst.org/uploadedFiles/Team%20Update%209.pdf
They have noticed the different numbering. They have also made some modifications to the trailer hitch drawings for reasons explained in the update.
Oh, and the inspection documents are available. There are some other more minor things too, but you'll have to read the update to get them.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 03-02-2009, 17:52
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: Update #9
Am I correct in reading the match sequencing part to think that the common practice of using switches on your OI to choose autonomous programs, starting positions, etc. before the start of autonomous mode will no longer work? Looks to me like the only way to provide program selection input to the robot will be by setting switches etc. on the robot itself. That sucks.
Unread 03-02-2009, 17:58
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Update #9
According to the following post on the FIRST forums, the DS data will be passed in Autonomous Disabled, so there won't be a problem. http://forums.usfirst.org/showpost.p...96&postcount=4
Unread 03-02-2009, 18:01
Software Engineer
Rookie Year: 1995
Re: Update #9
Good. Thanks for passing that along.
Unread 03-02-2009, 18:22
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
Re: Update #9
During each MATCH, the Field Management System will cycle each Driver Station though
the following states:
* Autonomous - Disabled
* Autonomous - Enabled (for 15 seconds)
* Teleoperated - Disabled
* Teleoperated - Enabled (for 120 seconds)
They should probably update this Q&A because it doesnt transition seamlessly from auto to teleop (it goes through a disable state for atleast 2 periods, ~0.04 sec)
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 03-02-2009, 19:57
Jimmy K's Avatar
Jimmy K Jimmy K is offline
FRC #1002 (Circuit Runners)
Jimmy K is an unknown quantity at this point
Re: Update #9
Am I the only one who can't find the new drawings? I have only been able to find the old drawings. Could anyone post a link to the new drawings? Thanks.
The Q&A says that there will be a "negligible delay". 0.04 sec is fairly negligible for the drivers and players, which is probably what the asker wanted to know. This is compared to usually a 2-20 second delay during previous years. Of course, the Q&A should probably add those details to the Q&A post.
Unread 03-02-2009, 20:36
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
Rookie Year: 2007
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Update #9
So after the autonomous is over, does that mean the payload specialist has to wait for tele-op to start before scoring again?
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 03-02-2009, 20:42
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: update #9
I'm not finding drawing GE-0940 Rev B. The update says it's in Section 8, but I don't see it there. Nor is it with the Game specific drawings in Section 6.
Am I misguided, or what?
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 03-02-2009, 20:45
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Re: Update #9
I don't think it will matter. Not much action will take place during the .04 seconds that things will be in the disabled state. Even balls in the air won't move much during that time slice. The processor might be able to add a few integers or a real number or two during those 40 miliseconds, but not much else.
Former Mentor Team 1771
Former mentor Team 4509
Unread 03-02-2009, 21:02
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: update #9
I can't find it either. The Game specific drawings have GE-0940 Rev A, but there is only the original trailer hitch diagram in it. I guess they must not have posted it yet or have hidden it with great skill.
Mods, should this thread be merged with the other update 9 thread? http://www.chiefdelphi.com/forums/sh...686#post813686
Unread 04-02-2009, 08:27
Snake Doctor Snake Doctor is offline
FTC #0498
Snake Doctor is an unknown quantity at this point
Re: Update #9
Good, other people are having trouble finding the new drawings for the trailer hitch. I thought I was just web site incompetent.
Unread 04-02-2009, 09:52
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Update #9
Has anyone asked Q&A about it?
(since 2004)
Unread 04-02-2009, 10:33
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Update #9
The presence of a disabled state between autonomous mode and teleop can have an effect on teams using single-acting pneumatic solenoid valves...
  #15   Spotlight this post!
Unread 04-02-2009, 10:46
Re: Update #9
The new drawing has been posted at the end of Section 8 on the 2009 FIRST Competition Manual and Related Documents page.
Looks like a shorter (3") length of Andy-Mark chassis material (C-channel) is allowed for the trailer mount bar. Presumably this avoid interference of the mount with the hitch tongue given the larger (3/8") clearance hole in the hitch swivel.
Update 13 Tomasz Bania General Forum 6 27-02-2006 23:12
Update 12 Tomasz Bania General Forum 1 25-02-2006 13:59
Update 10 Tomasz Bania General Forum 2 20-02-2006 22:41
update #7 Cobra Electrical 1 11-02-2003 14:57
