Go to Post If you are new to these forums, you might want to observe the discussions a while before diving in with opinions, emotions, and expertise. - Andy Baker [more]
Unread 03-02-2009, 22:34
manderson5192 manderson5192 is offline
AKA: Matt Anderson
FRC #0948 (Newport Robotics Group: NRG (pronounced eNeRGy))
Rookie Year: 2007
manderson5192 is on a distinguished road
How to change module slots in code
Hey guys,
Whenever the electrical team moves the modules around in the cRIO and doesn't put them back where they go, our software runs into a problem. Basically, the console output talks about mis-allocated ports for each of the modules in the cRIO (this makes sense). It also seems to shut down all the outputs from the system (PWMs, digital, etc).
I tried calling the SetDefaultDigitalModule function from SensorBase.cpp, but that didn't seem to do the trick.
I'm clearly missing something. Has anyone gotten this to work?
Thanks,
-Matt
how to build a VEX programming module bblack7489 FIRST Tech Challenge 78 09-06-2011 16:03
how do i change the db? explodingcan 3D Animation and Competition 3 15-02-2008 18:35
How to make vex programming module Eisner664 General Forum 2 20-04-2006 19:00
how to convert Easy C code into real code? TheHolyLancer Programming 1 29-01-2006 09:09
How do I change my gallery picture? MarkF CD Forum Support 2 26-03-2003 10:26
