Go to Post It's not fair. it's not right, but stuff like this happens. If you don't get picked for finals tomorrow, get in those stands and cheer for those who did. Remember, this is FIRST. - wilsonmw04 [more]
Unread 03-02-2009, 23:31
s0crates s0crates is offline
s0crates is on a distinguished road
bit banging on cRio?
I want to wire up a COM port to the gpio - one pin per input, using 9 total. How would I wire that? Would I conect ground and +, and have the signal pin as the only one connected to the serial?
-jonathan
Unread 04-02-2009, 08:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: bit banging on gpio?
I'm sorry, but I don't understand. I recognize all the words, and the question should make sense, but things just don't add up.
I usually think of "COM port" as referring to a computer's serial port. Is that what you mean?
Where do you have "9 total" inputs?
Do not connect ground and +. That's a short circuit, and you'll trigger the Digital Sidecar's overcurrent shutdown.
The voltage on a computer serial port follows the RS-232 standard, and is not directly compatible with the TTL-level signals of the Digital Sidecar. You'd need a level translator such as the MAX232 series.
Unread 04-02-2009, 08:48
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
I think the number "9" came from the number of pins on a standard DE9 RS-232 connector.
You will need one of these: http://en.wikipedia.org/wiki/MAX232
So you would only need a maximum of 4 signal lines between the MAX232 chip and the GPIO pins - Rx, Tx, RTS, CTS. RTS and CTS are optional (you probably won't need them for PC communication). This is in addition to +5V and GND needed by the MAX232.
Here is a kit which comes with easy-to-assemble components to go from a serial cable to your microcontroller. And it costs all of $7.
Unread 04-02-2009, 10:43
That mostly answers my question, but how do I wire the digital io board to the 4 signal lines from from the DE9 (via the max232)? Just leave the other two?
Thanks for the tip about the max232, I think I would have embarrassed myself without that.
-jonathan
Unread 04-02-2009, 11:49
Software Architect
You're using terms that don't match the names of the 2009 FRC Control System components, and that's keeping me from fully understanding what you want to do.
When you say "digital io board", do you mean the Digital Sidecar? If so, then you wire signals to the "signal" pins of the GPIO headers.
What "other two" are you referring to?
If you want to connect to a computer's serial port for communication to and from the cRIO, you really only need two signals: TX and RX.
Unread 04-02-2009, 12:21
sorry, digital sidecar. The other two I'm talking about are the two pins used for power - the two that are closer to the edge of the sidecar.
-jonathan
Unread 04-02-2009, 13:58
You can get power from the +5 and GND pins of any unused digital input. Connect the Rx and Tx lines to two unused digital input signal pins.
Unread 04-02-2009, 14:57
Re: bit banging on cRio?
I guess it wasn't very clear - do I need to wire up the two unused pins in some specific way, or do I only connect something to the signal pin and leave the other two unwired and in the same state as when they're unused?
-jonathan
Unread 04-02-2009, 15:22
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Before you get too far down this path, have you done the research to verify that it is possible to bit-bang a serial port on the cRio? Bit-banging RS232 requires very precise timing that may be difficult to achieve on the cRio, depending on how quickly the signal gets through the FPGA and into the cRio, how quickly your timer ISR is called by the OS, how quickly an output pin really changes after you tell the FPGA to change it, etc.
I haven't done any experiments yet to see what these delays look like, but it wouldn't take much to screw up the tight timings necessary for serial, especially at higher baudrates.
Unread 04-02-2009, 15:30
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
My first thought was to take advantage of the SPI/I2C interface with something like a MAX3110.
Unread 04-02-2009, 15:36
Software Engineer
Rookie Year: 1995
Exactly. I recently designed an I2C->Serial converter board using an Atmel ATtiny AVR for a situation similar to this. The necessary microcontroller and MAX232 clone cost less than $5 together.
pic: A "Bit" of a problem. Herodotus Extra Discussion 26 11-10-2007 01:53
A bit of humor... 114Klutz Chit-Chat 0 01-04-2006 17:34
16 bit math on PIC sciguy125 Programming 17 07-10-2005 02:57
A bit unfair... Martin General Forum 61 26-02-2002 07:48
i am a bit miffed Zeinin 3D Animation and Competition 3 18-01-2002 13:39
