Go to Post No, but you have access to the most powerful machine tool of all; a telephone. We had zero machining sponsors, now we've probably had over 30 unique shops run parts for us; All we did was ask. - AdamHeard [more]
Unread 04-02-2009, 07:41
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Question Labview questions, using motor and pot as a servo
Since there is no FORTRAN compiler for the cRIO , I am trying to do some programming in Labview. I have a motor attached to a 10 turn pot, and want to use it like a servo. Has anyone written a sub-vi that will take as input a desired pot reading and move the motor as required to achieve that reading? If so, would you be willing to share it?
Also, I am using a PID vi to track the target with the camera, and would like to set a larger deadband (the turret "hunts" back and forth trying to center the target, and I want it to stop when it's "close enough".) I have played with the PID constants, but can't stop the hunting, and there doesn't seem to be a deadband constant.
Former Mentor Team 1771
Former mentor Team 4509
Labview servo motor PWM correlation to set VI mbone206 NI LabVIEW 4 30-01-2009 14:58
Tracking Servo motor with drive motor in Labview mbone206 Technical Discussion 5 28-01-2009 17:32
Autonomous questions (Labview) and some general issues Daniel_H NI LabVIEW 15 08-01-2009 21:07
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
Students build SEGWAY in 3 months using Labview and the cRIO neutrino15 Programming 31 27-04-2008 22:08
