| View Poll Results: Anyone ever had trouble with the toughbox motors before | |||
| Ooh Yes! |
10 | 29.41% |
| Nope |
23 | 67.65% |
| Do not use them |
1 | 2.94% |
| Multiple Choice Poll. Voters: 34. You may not vote on this poll | |||
Toughbox Gearboxes
Whenever we turn the robot on the axel with one of the gear pops out and that falls down. The ball bearing has not popped out except for the first time today. Any reason why this would happen?
Re: Toughbox Gearboxes
Did you put the bearings in the right way, with the flange on the inside of the transmission, so they can't fall out?
http://lib.store.yahoo.net/lib/yhst-...rGuide2009.pdf
Above is a guide on how to assemble the toughbox. Hope this helps. |
yup they are on the inside
according to the instructions they are assembled the right way but the axel is still popping out
Just double checking, which gear and shaft is popping out? There are normally 4 gears in a toughbox and are driven in the following order:
CIM 14 tooth (On the motor) drives a 3/8" Hex 50 Tooth gear which is on the smaller of the two shafts. 1/2" Hex 14 Tooth on the same shaft then drives a 1/2" Hex 50 Tooth gear which is on the output shaft. The more detail you can give me, the more I can help you. The other thing I could see is the output shaft pulling out if you really wore down some areas. But this is pretty unlikely. The other likely option is that the gear on the motor is pulling off, which would be the result of a missing key/retaining ring. But that doesn't really go with the bearing/shaft problems your talking about. The more detail you can give us, the more help we can provide. Last edited by AndyB : 04-02-2009 at 14:29. |
We've had the push nut on the motor shaft works it way out until the key fell out. This cause one of the motor to spin freely. The only issue I see is the push nut. I'd prefer a set screw or event better an E-clip design but that would require machining the motor shaft. Some teams may not have the resources for machining the shaft.
I know I'm forgetting some details here because I didn't do this myself, but when I find out exactly how we fixed it I'll repost. |
Thanks we will try these at the meeting tonight and see if it makes a difference
#10
http://www.chiefdelphi.com/forums/sh...7&postcount=10
Is this the type of problem you are referring to? |
#11
No it's not the keys. we had that problem last year in which we lost the keys and we could not find them.
#12
#13
The only thing better in my opinion would be a snap ring, which isn't possible to do without disassembling and permanently damaging the motor. |
#14
One of our toughboxes had a problem with the key in the motor shaft jumping out and getting stuck in th grease on the inside.
It can be a good idea to put duct tape over the extra holes (keeps dirt out and keys in). |
| Toughbox mounts | Adama | Inventor | 6 | 28-01-2009 13:54 |
| modified toughbox | gorrilla | Technical Discussion | 7 | 02-04-2008 17:13 |
| toughbox plastic side | Andy L | CAD | 1 | 06-02-2008 23:26 |
| Toughbox broken | Evert | Kit & Additional Hardware | 5 | 05-02-2008 23:43 |
| Toughbox Assembly | mjgard | General Forum | 39 | 16-01-2008 19:27 |
