Go to Post I would contend that you cannot have a consistently good robot without equally good teambuilding. - jonathan lall [more]
Unread 04-02-2009, 14:44
EuTu EuTu is offline
FRC #1396 (Pyrobots)
EuTu is an unknown quantity at this point
No Idea what's wrong!
This is probably a combination of programming and/or electrical. All of the wires are connected correctly, as per the diagram at least. I am also 'feeding' the watchdog, and the driverstation reads 00.00 V and when i try and output anything tothe console right now is shows a 0x160a68 task, errno 70 or 71. What is the 70,71 mean, and how can i get the robot to run. I configured the cRIO to work with the router, and everything works because it allows me to connect to the cRIO and download code/undeploy code. I am desperate, ive tried literally everything to get the robot to run, and still doesn't!
Unread 04-02-2009, 15:05
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: No Idea what's wrong!
I'm note sure about the error numbers you report but in general:
1. Did you update to 3.0a for Labview?
2. Did you successfully reimage the cRIO afterward?
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 04-02-2009, 15:17
I use WindRiver, I imaged it as soon as i connected it. Now, nothing is working. The Jaguar lights aren't solid anymore, they're blinking.
Unread 04-02-2009, 15:27
IT WORKS!! sorry, thanks.
Unread 04-02-2009, 15:59
Unsung FIRST Hero
Electrical Engineer
Rookie Year: 1995
Please post the reason so that others can learn from your experience...
Mike Betts
Figure out what's wrong with the IR board sparrowkc Electrical 5 17-02-2008 12:29
What's Wrong with our Gyro??? manderson5192 Programming 4 08-02-2008 09:08
pic: What's wrong here? Branden Ghena Extra Discussion 15 30-03-2007 11:20
pic: What's wrong with this picture - Why were we shut off? CD47-Bot Extra Discussion 12 04-10-2004 19:16
"What's It" Game Idea sanddrag Games/Trivia 0 21-07-2004 01:28
