Whats up with registration
I can't register there is some proxy error. someone please help!
Sounds like some kind of network problem. Too bad I don't know more about networks. Sorry
Since I am not a network specialist, so I am just guessing what the problem is
Are you behind a firewall? If you are, the specific port that FIRST uses to send the data is blocked. You if you can turn off your firewall for the duration of the registration? Your proxy settings might be messed up. There are so many proxy settings like SOCKS4, SOCKS5, HTTPS, and so on. If your web browser is misconfigured that might cause an error. To correct this you have to go into your preferences, inside your browser. On IE 5 it is Edit>>Preferences>>Network>>Proxy Settings Than click off any proxies that you are using, for a temporary time. Than try to register. |
registration problems?
i had the same problem joel
now i can say im not going crazy.
According to the message I am getting, the FMPro server is not responding; its something on their end...
mine does the same
While I'm not totally sure what the problem is, at least when I experienced it the past couple days, the error was intermittent. I believe it's simply the fact that their database server is overloaded at the moment. Just give it a bit of time and try again later. It usually comes back up.
Matt |
| FALL FURY Registration Open | DirtyBird213 | Off-Season Events | 1 | 09-09-2003 08:46 |
| Championship Registration Filled | Travis Hoffman | Championship Event | 0 | 01-04-2003 21:20 |
| Duel on the Delaware Registration NOW OPEN TO ALL | John Larock | Off-Season Events | 0 | 30-08-2002 07:24 |
| Ford Sweet Repeat Invitational registration forms available | archiver | 2000 | 2 | 23-06-2002 23:15 |
| Some registration Stats. | P.J. Baker | General Forum | 3 | 12-12-2001 15:29 |
