Go to Post I'm glad to be on the same team as smart people. - Andy Baker [more]
Unread 04-02-2009, 18:35
odin123's Avatar
odin123 odin123 is offline
AKA: Dantheman
FRC #3044 (The Robonators)
Team Role: Student
odin123 is on a distinguished road
The Robonators 09
Rookie team 3044. So far so good! We have our drive system all set and are working hard to get the retrieval system all set. We also are creating our hopper and shooting mechanism right now.
http://s673.photobucket.com/albums/v...t=DSC00017.jpg
Unread 04-02-2009, 20:04
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Rookie Year: 2007
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: The Robonators 09
from the looks of it so far so good... though one suggestion.
from the picture it looks like you are going to be using wood on the frame of the robot... (from the one attached in front of the wheels). If you are planning to use a wooden frame I'd suggest switching to a more durable material like metal. This year is going to be a high contact, hard collision game and with the weight of the robots combined with the speed they will be hitting each other there will be allot of force and I'm not certain if it will be able to hold up to the repetitive impacts. We tried using wood our first year and we got taken apart.
good luck to you!
FEAR THE HAWK!!!
Unread 04-02-2009, 20:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
First off, if properly used, wood can be a perfectly acceptable material to use for a robot chassis. 1726 and 1771 both choose to go that route this year and have posted pictures of their robots. I doubt either of these robots will fall apart.
Second, there chassis appears to be made of metal. The wood looks a lot like the start of a set of bumpers to me.
Unread 04-02-2009, 20:18
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
If you look closely at the picture, the frame is metal. The bumpers (currently being built I believe) are made of wood.
Looks good 3044! Hopefully you can wrap it all up soon!
Best of wishes!
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 04-02-2009, 22:07
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
I will gladly put our wooden chassis up against any metal chassis this year, and with the exception of possibly a couple teams, I guarantee our chassis will be stiffer and probably lighter. Wood when used properly, and when quality wood is used is incredibly strong and far lighter than aluminum (~1/7 density of aluminum). Our chassis was built with tongue and groove construction and all joints were glued using high quality boat building epoxy. We also used a highly specialized okoume plywood. Needless to say wood can work and in my opinion is the ultimate material for a drivetrain.
Mentor 2415
Unread 05-02-2009, 00:28
Hegemoni's Avatar
Hegemoni Hegemoni is offline
Seniors 09
AKA: Ben Gilbert
FRC #0148 (Robowranglers)
Hegemoni will become famous soon enoughHegemoni will become famous soon enough
Send a message via AIM to Hegemoni Send a message via MSN to Hegemoni Send a message via Yahoo to Hegemoni
Dang, that is an old looking computer...
But on a (significantly) more related note: It's looking good
I think I see a roller there on the bottom, so I assume you're picking off the ground
are you gonna be player fed at all?
Good luck on the shooter!
Unread 05-02-2009, 00:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Old is relative....I finally retired this one in 2005
Nice progress on the robot! Good to see you're working on the bumpers already as they are pretty important to the overall robot chassis design this year.
Unread 05-02-2009, 06:51
Mikesername's Avatar
Mikesername Mikesername is offline
meh.
AKA: Mike Dame
FRC #3044 (Team 0xBE4)
Mikesername is an unknown quantity at this point
Send a message via AIM to Mikesername
We are planning on being player-fed as well.
And on another note, the wood there isn't part of our actual frame. As some people have pointed out, the frame is metal.
[ ballston spa robotics | www.team3044.com | team BE4]
Unread 08-02-2009, 22:37
b williams b williams is offline
FRC #3044
b williams is an unknown quantity at this point
yea, we're adding an open hopper on top, that way we can pick up and carry multiple orbit balls as well have a player toss them into the top of the hopper
Unread 15-02-2009, 11:07
Garii's Avatar
Garii Garii is offline
Registered Abuser
AKA: Jared Hankle
FRC #3044 (BE4)
Garii is an unknown quantity at this point
Send a message via AIM to Garii
Funnt Story, That computer is What runs our CAD
Its Got WinNT 4.0 on it i think.
-The Garii- aka Jared Hankle
Ballston Spa Labview Programmer
new team slogan-"Can I Get Some Linux With These Fries?"
From the Ice Age to Robot City. The Few, The Proud, The Machines (new movie) Elgin Clock Televised Robotics 21 14-03-2005 15:14
Survey of the 2004 NJ Regional- The good, the Bad and the So-So Rich Wong Regional Competitions 23 10-03-2004 06:23
pic: The Man, The Myth, The Legend, The Symbol CD47-Bot Extra Discussion 6 09-04-2003 02:48
